Re: Spitfire windshield wipers getting old and slo
Could be both, but more probably the motor. The cable and wheelboxes will wear, but for the most part they don't get that badly gummed up. The motor crank will get stiff, though, or the electrical brushes in the motor will wear down.
Its easy enough to disconnect the motor and open the crank case, clean it up and re-lube. Put it back in and try it out. If you want to go further, checking out the brushes involves opening up the motor case (just two long screws as I recall).
While the motor is detached, take the wiper blades off and try moving the wiper cable in and out just using your hand. It should push and pull very easily, if it is binding up you should be able to feel it. I think the spec for this if you want to hook a spring gauge on the end is that it should take less than 6 pounds to pull the cable with no wiper blades attached. Usually it is very easy to move.
Pulling the wiper cable out is no big deal either, but you will have to remove the package trays to access and loosen the nuts on the bottom of the wheelboxes that hold the cable in (just loosen). The cable just pulls right out and you can check it for wear and lube it on the bench. Sometimes you will need to slack those nuts right off when you come to put the cable back in, because you need to thread it through those aluminum tubes which are held in place on the bottom of the wheel boxes.
The wheel boxes themselves can bind also, but if you take the cable out you can unscrew the top nuts that hold the wheel box against the body and they can also be removed.
