Spitfire Spitfire MK1 or 2 gas pedal bushings
JKB1957
Okay, so I'm trying to put the gas pedal linkage back on my Spifire Mk2 and I am replacing the 2 bushings that the linkage fits into. One on each side of the bulkhead, facing each other. I have tried brute strength (forcing them in)and they crumble. I have warmed them, they crumble. I have soaked them in very hot water, (accelerator bushing tea anyone?)they dissolve. Is there some archaic trick, known only to Druid's and very old Triumph assembly line workers, on how to fit these things? Or is it just get them to fit the best way possible and hope.
myspitfire
:savewave: <span style="color: #009900"> </span> <span style="font-size: 12pt"> </span> NOPE!.Your on the right track...Watch you don't shoot yourself in the foot :lol:
billspit
I replaced mine and the only thing I can offer is to try silicone spray. I do recall they were a bear to get in, but I only needed one set.
ArcticOne
AM having to do mine on the GT6 this winter. Where did you end up purchasing yours?
And did you use the rubber, nylon or plastic?
Thanks
jb
ArcticOne
I read on another forum to microwave the bushing for about 3 minutes. Apparently it comes out soft and pliable, but hardens once it cools down.
Supposedly it makes install a bit easier.
jb
ArcticOne
Here's a link to the discussion:
Nuked Pedal Bushing
Although it is from a TR6 hopefully it will apply to yours as well.
And hopefully in the various jumble of terminology that the linked thread and this thread are actually talking about the same bushing bearing thingy.
jb
ArcticOne
Wanted to see how the pedal bushing install turned out. Just ordered a set for the GT6 and looking at seeing if the microwave worked.
jb
J
JKB1957
Well I tried nuking the bushings. Stopped at 1 minute as they had actually melted. Ended up using some nylon bushings from a local hardware store. They seem to work well, a little play but this should be resolved when I attached the spring from the lever to the frame. Good luck with yours.
ShawnC_at_Moss Spitfire New catalog includes Spitfire Mk1, 2 & 3 Triumph 6
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
JBann Spitfire Oil Filter for Mk1 Spitfire Triumph 7
JBann Spitfire Do you think it's worth it? - 1964 Spitfire MK1 Triumph 33
JBann Spitfire Triumph Spitfire mk1 - Height restrictions? Triumph 24
J Spitfire Spitfire MK1,2, or 3 trunk help Triumph 0
T Spitfire Help and Picture need for a mk1 spitfire Triumph 1
T Spitfire Spitfire top install mk1 or mk2 Triumph 2
T Spitfire Spitfire mk1 breather tube Triumph 14
T Spitfire Will not restart after warm up, Spitfire mk1 Triumph 15
G Spitfire mk1 mk2 spitfire clutch conversion ?'s Triumph 7
B Spitfire Spitfire Mk1 Rear Anti Roll Bar / Sway Bar Triumph 3
B Spitfire Spitfire Mk1 Steering Rack - can there be stops? Triumph 0
B Spitfire Spitfire Mk1 Rear Spring Shape Triumph 7
B Spitfire Tandem Brake Cylinder on a Spitfire Mk1 Triumph 4
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 5
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
T General Tech Spitfire overdrive, the sequel Triumph 3
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
glemon Spitfire Spitfire for the Win Triumph 5
P For Sale '78 Spitfire Frame Triumph Classifieds 0
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
