Spitfire Spitfire 1500 - Front Pulley Nut Removal?
dklawson
I am working with my son to stop a front of the engine oil leak on his 1500. We are replacing the sealing bar, pan gasket, front plate gasket, timing cover gasket, and front seal. To do this we need to get the crank pulley off.
Our pulley nut won't budge. I have put a wedge between the block and crank and used a huge socket with a lengthy breaker bar on it. It won't move. I'm afraid if I pull any harder the huge breaker bar will break.
I have tried my impact wrench and while it is good, it cannot move this nut either. I may bring home a bigger impact gun from work to see if it is up to the task.
The manual says these things go on with 110 ft-lb. I know we've been pulling with somewhere between 2 and 3 times that. What should we try/do to get that front pulley nut off the crank?
All advice is welcome.
Doug L.
trrdster2000
Doug, this has been a problem for a lot of people. You can do this at your own risk. Brace your bar on the frame and hit the stater.
Wayne
dklawson
dklawson
Thanks Wayne. I thought about trying that. It is a method that is also used on A-series engines. In the end I was afraid of what might happen... just like I was afraid of all the torque I was putting on the breaker bar.
In the end I did get the nut off. I sprayed the nut liberally with PB Blaster and hit it again with my impact wrench. However, I alternated between tightening and loosening to shock the joint in both directions. After about 5 minutes of that I noticed the nut slowly starting to move counterclockwise and then all of a sudden it hit the sweet spot and spun off. What a ridiculous amount of torque.
Thanks again for your suggestion.
dklawson Spitfire Spitfire MkIV/1500 - Factory Front Spoiler? Triumph 3
C Spitfire Front Lowering an 80 1500 Spitfire? Triumph 6
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 5
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
R Spitfire Spitfire 1500 Triumph 3
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
B Spitfire Advice on swapping to J Type OD with 1500 engine in 69 Spitfire Triumph 13
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
S Spitfire 1973 Spitfire 1500 Dashboard question about warning light Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
F Spitfire Spitfire 1500 Dash Lights Triumph 1
W Spitfire Spitfire 1500 Steering Column Triumph 3
dklawson Spitfire Clutch Kit Preference - 1500 Spitfire Triumph 3
Anthony_S Spitfire Spitfire 1500 for sale in my area Triumph 1
S Spitfire Is a 1973 spitfire a 1500 or a mark IV? Triumph 7
dklawson Spitfire Spitfire MkIV/1500 Body Gaps - Bonnet to Bumper Triumph 2
F Spitfire Spitfire 1500 Door Handle Removal Triumph 1
F Spitfire SUs On a Spitfire 1500 Triumph 14
Scott_Hower Spitfire Late Spitfire 1500 CV driveshaft Triumph 3
F Spitfire Spitfire 1500 - Stromberg CD 150 Question Triumph 9
F Spitfire 1500 Spitfire Windshield Glass, Gasket and Install Triumph 12
Don_R Spitfire Spitfire MKIV/1500 parts book Triumph 2
F Spitfire Spitfire 1500 Electrical Question?????? Triumph 4
F Spitfire 77 Spitfire 1500 Questions Triumph 3
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
mikecyc72usa Spitfire First Autocross in my Spitfire 1500 Triumph 29
F Spitfire 1500 Spitfire Engine Noise Triumph 14
A Spitfire TRIUMPH SPITFIRE MKIV 1500 Triumph 2
K Spitfire 60’s spitfire body swapped onto a 1500 cassis Triumph 3
M Spitfire Spitfire 1500 OD transmission Triumph 9
A Spitfire Triumph Spitfire 1500 Triumph 8
K Spitfire Spitfire Mk IV tonneau =Spitfire 1500 tonneau? Triumph 2
dklawson Spitfire Crank Endfloat and Oil Pumps - Spitfire 1500 Triumph 9
bowiderberg Spitfire Whitworth on a Spitfire 1500? Triumph 8
This14u Spitfire 1500 Spitfire Header Recommendation Triumph 0
pjsmetana Spitfire Spitfire 1500 TC Triumph 2
frankenstang57 Spitfire Spitfire 1500 fast road cam question Triumph 4
1965_MGB Spitfire Junkyard Find, Spitfire 1500 I think Triumph 6
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
roofman Spitfire Anti run on valve ? spitfire 1500 Triumph 3
c5racer Fit an exhaust manifold from a 1500 Spitfire? Spridgets 2
Dudly Spitfire 1500 Spitfire Pureist beware Triumph 19
