Hi Jim,
This is a *good* example of why I really dislike it that a couple of the big, US LBC vendors insisted on creating their unique parts numbering systems and don't cross-reference with the original factory numbers used by most everyone else! VB & Moss' numbering systems just make it impossible to compare between vendors (which is exactly why they do what they do, I'm sure) or to be certain you are getting the correct part! Climbing down off my soapbox now... rant over. /ubbthreads/images/graemlins/wink.gif
Andy might be right, if that is a GT6 frame (I dunno if it's possible, am not that familiar with Spit/GT6 interchangeability) *and* they used the GT6 rear spring that was fitted to it, I would tend to think it's too heavy a rate for the lighter car (GT6 front coil springs would probably be okay with the heavier engine). *However* see note below about later Spit/GT6 springs at Rimmer Bros.
I have a Spitfire Mk III factory parts catalog that lists three different springs (I don't have a GT6 parts manual). OEM springs offered were: Standard 305894, Rally 307027 (heavy duty, with two people in the car), and Race 306677 (heavy duty, with driver only). It appears the only difference is the main leaf of the spring, which was originally available separately under the same numbers as above, except with an "/M" suffix.
Rimmer Bros. shows the Standard spring number listed above used on Spitfire Mk I, II and III. They don't list either of the uprated performance springs (nor does The Roadster Factory). GT6 Mk 1 and post-Rotoflex use a different spring: 307324, according to The Roadster Factory.
Interestingly, Rimmer shows Spit Mk IV and 1500 using the same spring as GT6 Mk III (non-Rotoflex): 159640, in spite of Andy and my suspicions that the heavier car would have a heavier spring!
Although not applicable here, Rotoflex GT6 (Mk II and some Mk III) appear to use a different spring altogether: 308499, according to Rimmers.
Perhaps there is a part number stamped somewhere on the spring and the above info will be useful (however, the numbers were painted on my TR4's leaf springs, and illegible after 40 years).
Other than that, is it possible the spring or any of the other rear suspension parts are installed wrong?
If necessary, a local truck shop could probably re-arc the spring, as Andy mentioned.
Don't know if this helps or not. Please keep us posted on any additional info.
p.s. Canley Classic's online catalog confirms the above factory numbers, and also lists two different springs for Herald and Herald Estate/Vitesse.
