Spark plugs
BJ8TONY
Hello and happy 4th to all.
So my Healey is about to hit the road this summer and I was wondering what are good spark plugs to use these days.
I am running a Mallory dual point distributor and triple side draft DCOE webbers.
NGK BP6ES. Not a fan of platinum, or other exotic hype.
I'm also running a Mallory (now single-point "trigger" with an MSD 6ALII) & 3 X Weber 45DCOE.
I've tried both 5s & 7s, but the BP6ES was the best.
Keoke
OH you can't go wrong with a set of those Bosh Platinums type WR7DP--- :laugh:
B
BJ8TONY
Randy what sre you running for jets in the webbers?
I ask because I have had a problem with a little popping back when I lift off the throttle which I think is caused by the carbs leaning out.
I set them up using the recommended jets per a webber book that I have.
trglory TR2/3/3A TR3a spark plugs Triumph 1
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
kodpkd Spark Plugs Austin Healey 3
L TR4/4A spark plugs Triumph 9
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
tahoe healey Spark Plugs Austin Healey 20
G spark plugs Austin Healey 10
vickxxx T-Series 1952 MGTD spark plugs. MG 4
Simon TR4a TR4/4A Spark plugs, what do you use? Triumph 4
gbtr6 TR6 What spark Plugs do you use? Triumph 1
S MGB 1969 MGB No spark to plugs MG 5
R Spark plugs for 61, BT7 Austin Healey 2
M TR4/4A Spark plugs. Triumph 1
T TR4/4A What gap on Champion L-87YC spark plugs? Triumph 3
sim Dead spark plugs ? Spridgets 52
tinman58 General Tech Bad spark plugs Triumph 7
K TR2/3/3A NGK BPR5HS spark plugs I believe are one stage hotter.... Triumph 5
S TR2/3/3A TR3A Spark Plugs Triumph 4
JPSmit How often do you change your spark plugs? Spridgets 7
R Mixing spark plugs Triumph 10
B Spark plugs with Webers Austin Healey 6
Patrick67BJ8 Spark Plugs for '67 3000....what kind? Austin Healey 23
K TR4/4A NGK Spark plugs BPR5HS for TR3A/TR4A Triumph 3
Flash_Harry Any thoughts on these spark plugs? MG 9
M Spark Plugs!!! Triumph 13
D Read Spark Plugs Spridgets 21
fad64b NGK Spark Plugs Triumph 2
JodyFKerr Fighting with spark plugs in an Explorer Other Cars 19
Randy Forbes Platinum spark plugs...? Austin Healey 7
Musicman Spark Plugs - Champion or NGK Triumph 13
SkinnedKnuckles Lasers to Replace Spark Plugs... Triumph 1
S Spark plugs Triumph 20
M 100M spark plugs Austin Healey 2
TR6oldtimer Reading spark plugs as a tuning aid Triumph 19
R Compression/spark plugs Spridgets 13
TR6oldtimer TR6 TR6 spark plugs Triumph 7
Grampy spark plugs Racing 2
A no spark to plugs!!! Triumph 20
C Best Spark Plugs for BJ8 Austin Healey 14
texas_bugeye Spark plugs Heat range Ethl blended fuel Spridgets 6
Stinger TR4/4A TR4A Spark Plugs Triumph 8
