One additional thought.
It is always better to start out too cold versus too hot. Too hot plugs can lead to detonation and/or pre-ignition. Detonation and pre-ignition do bad things to piston tops and ring lands. Too cold a plug just results in fouling, but nothing is impacted other than the plug. For NGKs, the higher the number the colder the plug. Changing plug heat ranges results in approximately a 75 - 125 degree F difference in tip temperature. Sparkplug design might affect the actual number, but this range is close.
