Spark Plugs!
blkcorvair
Come to think of it I never seen a thread here on what type of spark plugs everyone is using... Since I just fouled and tossed my set I was wondering what type and brand everyone is using?????
Morris
I am curious about this too, as my plugs seem like they may be a bit too cold. They sure collect lots of crap.
racingenglishcars
Hotter plugs for generally lower speed driving, colder for generally higher speed driving, like a race car on the track. This is due to running a richer mixture at lower speeds (including acceleration) which burns colder, and a leaner mixture at higher engine speeds which burns hotter.
Generally start with N9Y or equivelant.
jcatnite
Bosch 4016 gapped to 0.025" in my 1500. They seem to do pretty well.
JC
aeronca65t
I've been running Autolite plug #54 which is similar to a Champion N11Y. They don't seem to get too hot and are cheap and easy to get (Autozone, etc.)
I change them about every other event. With the Pertronix and a big American car coil, I am running about 0.035" gap with pretty rich mix (and no fouling).
Pythias
i'm with glen NGK BP6ES in a 1098. i'm running a Crane electronic ignition, so i've opened up the gap to .030. been considering going even wider.
I'm a big supporter of NGK myself, been using them for almost 25 years, at the race track you'll see guys almost exclusively use NGK plugs, The higher the number the colder the plug with NGK. We've used as cold as #10s in the full prep race engines, we use #8s in the SCCA limited prep engines, and I think that is a good choice for you car on the race track, yu can get away with the projected tip as well until you get way up there in compression ratio, so I would suggest Scott a BP8ES, you can spend more money on the EV plugs, but they never showed us even 1 horsepower on the dyno, save your money and buy the ESs
trglory TR2/3/3A TR3a spark plugs Triumph 1
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
kodpkd Spark Plugs Austin Healey 3
L TR4/4A spark plugs Triumph 9
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
tahoe healey Spark Plugs Austin Healey 20
G spark plugs Austin Healey 10
vickxxx T-Series 1952 MGTD spark plugs. MG 4
Simon TR4a TR4/4A Spark plugs, what do you use? Triumph 4
gbtr6 TR6 What spark Plugs do you use? Triumph 1
S MGB 1969 MGB No spark to plugs MG 5
R Spark plugs for 61, BT7 Austin Healey 2
M TR4/4A Spark plugs. Triumph 1
T TR4/4A What gap on Champion L-87YC spark plugs? Triumph 3
sim Dead spark plugs ? Spridgets 52
tinman58 General Tech Bad spark plugs Triumph 7
K TR2/3/3A NGK BPR5HS spark plugs I believe are one stage hotter.... Triumph 5
S TR2/3/3A TR3A Spark Plugs Triumph 4
JPSmit How often do you change your spark plugs? Spridgets 7
R Mixing spark plugs Triumph 10
B Spark plugs with Webers Austin Healey 6
Patrick67BJ8 Spark Plugs for '67 3000....what kind? Austin Healey 23
K TR4/4A NGK Spark plugs BPR5HS for TR3A/TR4A Triumph 3
Flash_Harry Any thoughts on these spark plugs? MG 9
B Spark plugs Austin Healey 3
M Spark Plugs!!! Triumph 13
D Read Spark Plugs Spridgets 21
fad64b NGK Spark Plugs Triumph 2
JodyFKerr Fighting with spark plugs in an Explorer Other Cars 19
Randy Forbes Platinum spark plugs...? Austin Healey 7
Musicman Spark Plugs - Champion or NGK Triumph 13
SkinnedKnuckles Lasers to Replace Spark Plugs... Triumph 1
S Spark plugs Triumph 20
M 100M spark plugs Austin Healey 2
TR6oldtimer Reading spark plugs as a tuning aid Triumph 19
R Compression/spark plugs Spridgets 13
TR6oldtimer TR6 TR6 spark plugs Triumph 7
Grampy spark plugs Racing 2
A no spark to plugs!!! Triumph 20
C Best Spark Plugs for BJ8 Austin Healey 14
texas_bugeye Spark plugs Heat range Ethl blended fuel Spridgets 6
