Spark plugs for 61, BT7
rusty1c
What spark plugs should I use in my 61, BT7? It has been suggested that I use a Champion RN12YC. What affect will using a resistor plug have on engine performance and will it cause a colder spark due to the resistor?
Thanks,
Pete
rusty1c
I've used RN12YC for about 130K miles with no problems I can attribute to the plugs (rotors, wires, etc. well, that's a different story). I've used these plugs with modern, noise-suppression wires but these don't play well with the stock caps so went to stranded copper wire as original. Any equivalent plug--NGK come highly recommended--should work fine.
I believe the resistance in the plug is insignificant compared to the resistance of the gap.
Keoke
Any modern equivalent plug I like Bosh Platinum's
trglory TR2/3/3A TR3a spark plugs Triumph 1
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
kodpkd Spark Plugs Austin Healey 3
L TR4/4A spark plugs Triumph 9
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
tahoe healey Spark Plugs Austin Healey 20
G spark plugs Austin Healey 10
vickxxx T-Series 1952 MGTD spark plugs. MG 4
Simon TR4a TR4/4A Spark plugs, what do you use? Triumph 4
gbtr6 TR6 What spark Plugs do you use? Triumph 1
S MGB 1969 MGB No spark to plugs MG 5
M TR4/4A Spark plugs. Triumph 1
T TR4/4A What gap on Champion L-87YC spark plugs? Triumph 3
sim Dead spark plugs ? Spridgets 52
tinman58 General Tech Bad spark plugs Triumph 7
K TR2/3/3A NGK BPR5HS spark plugs I believe are one stage hotter.... Triumph 5
S TR2/3/3A TR3A Spark Plugs Triumph 4
JPSmit How often do you change your spark plugs? Spridgets 7
R Mixing spark plugs Triumph 10
B Spark plugs with Webers Austin Healey 6
Patrick67BJ8 Spark Plugs for '67 3000....what kind? Austin Healey 23
K TR4/4A NGK Spark plugs BPR5HS for TR3A/TR4A Triumph 3
Flash_Harry Any thoughts on these spark plugs? MG 9
B Spark plugs Austin Healey 3
M Spark Plugs!!! Triumph 13
D Read Spark Plugs Spridgets 21
fad64b NGK Spark Plugs Triumph 2
JodyFKerr Fighting with spark plugs in an Explorer Other Cars 19
Randy Forbes Platinum spark plugs...? Austin Healey 7
Musicman Spark Plugs - Champion or NGK Triumph 13
SkinnedKnuckles Lasers to Replace Spark Plugs... Triumph 1
S Spark plugs Triumph 20
M 100M spark plugs Austin Healey 2
TR6oldtimer Reading spark plugs as a tuning aid Triumph 19
R Compression/spark plugs Spridgets 13
TR6oldtimer TR6 TR6 spark plugs Triumph 7
Grampy spark plugs Racing 2
A no spark to plugs!!! Triumph 20
C Best Spark Plugs for BJ8 Austin Healey 14
texas_bugeye Spark plugs Heat range Ethl blended fuel Spridgets 6
Stinger TR4/4A TR4A Spark Plugs Triumph 8
