TR4/4A Source for air duct seal?
TR4eh
NLS at all the regular places. I'm looking for a suitable replacement rubber seal between the air duct and the plenum, part no. 610639. Perhaps a section of trunk seal would do. Anyone have a suggestion?
Thanks,
Cliff
dklawson
It looks to be a uniquely shaped part.
Since it should be a static seal I think your idea of using a length of tubular seal should work. Since I have not seen the actual parts I can only speculate that you might also be able to use some of that sticky-backed foam seal tape that is sold at home-centers. I know that is available in different widths and thicknesses. You might find that easier to shape and install depending on the mounting surfaces you have to work with.
T
TR4eh
Do you have a piece of the old one?
Yes, I have the old one(s). One is crumbling but the other side is OK. I'll see if I can match a cross section to something in Steele's catalog. I don't think it has to be custom molded, it fits around the end of the duct, so as long as it will bend around a curve I think a straight piece can be made to work.
DNK
There is another company too
I think Randy from WISSconSIN posted it
JerryVV
Call Scott Harper @ Team Triumph in Warren, OH 330-392-7176 after 11:00AM most days. Good guy and has lots of used parts.
HerronScott
That's disappointing to hear that seal is NLS.
Scott
alanjohnturner
I think these were originally made with at least one join glued together with impact glue.
I rather fancy its two pieces and they meet at the sharp corners and are mitred.
The material needs to be foam and very squashy. If think the kind of chunky anti-draught strip we put around doors might work.
T
TR4eh
I picked up some 1" wide self-sticking weatherstrip at the Home Depot, I'll let you know how it works out.
T
TR4eh
Got the job done today. Closed cell rubber weatherstripping around the plenum openings, and sections of trunk seal around the ducts. It closed up nicely.
T
TR4eh
That is good news. My TR4 would benefit from having Item No. 27 (https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29195&SortOrder=300) replaced, also. Could you be more specific about the "sections of trunk seal," please?
Gerald, #27 is a felt strip, roughly 1/4" thick and 1" wide. Its glued to the outside of the duct all around. The rubber seal between the duct and plenum is #23 (NLA). I used sections of #52 here: (https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29165#52)
Cliff
mperdue source for air filters MG 8
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
D General TR Front carpet source? Triumph 1
Steve P. Best source for new tappets? Austin Healey 11
I General TR Source for glass mirrors Triumph 5
