VelodromeRacer
OK, So I have installed the DW header, which required some effort, then replaced a faulty coil of all things, and changed out my old sparkplug wires with a new cap and silicon wires.
Now I have a question.
Before all of this, the car seemed to "cough" once or twice through the carbs when I started her cold. Now, she "coughs" a bunch when cold, and when you stand on the gas it does it even more! I am going to check the timing, but never having done that on this car, what should the timing be set?
Is there anything I should do with the adjuster on the distributor?
I also wonder if it is carb/fuel related?
Thanks for any advice.
