• Hi Guest! Being a Paid Subscriber is NOT required to participate at BCF. However, if you enjoy BCF and find our forum a useful resource...
    Please consider supporting us by **Upgrading**
MGB Smoking MGB
daver80
Member
Hi all! I've got a 66 MGB that has been sitting for about 2 years without running. No real problems, just got sidetracked with other stuff (translated- kids) Had been running great last time she ran. Engine, head, have about 15,000 miles since rebuild. Put 5 gallons of fresh gas in, changed the oil, charged the battery and she started right up (with choke, of course) She smoked badly at first- white smoke, not as much later. thought it would clear, idled about 10 minutes after I shut off the choke (jets stick a bit, have to push them in after engine is warm). Seemed to idle fine but still too much white smoke. I cleaned out the barrels in the SU's- they werent dropping properly ("clunk") I checked my oil- no coolant in oil- looks fine, checked plugs, look sooty black from running with choke on, but not oil fouled. Any suggestions before I dig into checking the lifters under the intake and exaust manifolds. Maybe I should just let it run longer to burn more of the old gas out of there? Opinions? Thanks!!! Dave P
Two words: OLD GAS!
Don't look for somethin' wot ain't there. Get it thru several "heat cycles" (up to normal temp) before making any decisions.
daver80
Member
Doctor- Thats good advice I really didnt want to go poking around too much- she ran so nice last time I drove her. I'll try running more ogf the gas out of her.
We owned an 84 300D for 8 years, sold it in 2004 with 230k. Ran like a top. is yours light metalic blue? Dave
Why, yes it is. Beast has well over a quarter on 'er, still putters along at 80 when asked. Took 'er on a 400 mile round trip this past weekend. Not a hiccup. Diesela's a good ol' girl. Bit "beamy" for my taste but <span style="font-weight: bold">strong</span>.
..."Brunhilde" wouldn't fit on a license tag.... :jester: :devilgrin:
philman
maybe you just have moisture in the exhaust system?
vping
Let er run and then change the plugs. I picked up a Bimmer recently, drained the gas and fired it up after a 5 years slumber. White smoke for a very long time and had me concerned. After running it for a good bit, she's fine. Bad gas and water in exhaust is what I attest it to.
Stewart
Give it 20 miles or so. My 73 smoked a bit at first and leaked oil like a sieve after not running for at least 8 years. After about 20 miles the smoke was gone and the oil leak slowed down to a silver dollar size puddle after being parked over night.
daver80
Member
I think I'll back her out, fire her up, air her up and let her run her a bit. Sounds like no need to panic just yet. Thanks!! Dave
not quite as glamorous a list:
66 MGB
67 IH Cub Cadet 122
86 BMW R80RT (110k bike)
89 Volvo 240 wagon (206k)
and an old 70's snowblower
glemon
Does a 66 have that crankcase breather PCV valve? If the diaphragm cracks on this you can pull oil into the intake and get lots of white smoke, back in college I had a head rebuilt on my MGB before I figured that out!
daver80
Member
Glemon- I'll check that out. All she has for emmissions is a disk shaped thing up on top with about 2 inches of tube. The plugs were sooty, but not oily. so I dont think oil is going into the combustion chamber, but I'll check that round thing- easy enough to do. Had it out twice now and still smokes. But I did get my turn signals working! Dave
That disk shaped thing is what Glemon is on about. The wire "spring" widget holds the cap in place, under it should be a spring and a diaphragm with a small "billet" valve vulcanized to the center. The diaphragm should be flexible and unsplit, the funnel underneath clean and free of carbon deposit.
daver80
Member
Dr / Glemon- I opened the disk (breather) tonight and saw a trace of oil in there, not a lot, but it was in there. The rubber wasnt cracked, but it wasn't new, soft and suple either. Those diaphrams are probably more $$ than I'm expecting, but maybe I should give it a try. At least price it out. Might even be a NAPA item- i might be suprized. Thoughts? Dave
I doubt you'll find one of <span style="font-style: italic">those</span> at NAPA. If it has no cracks and isn't brittle it should be fine. A trace of oil is normal too. Run it some more. My vote is still on old gas. Run what's in there out and refuel. Then see if the smoke clears.
Ken Lessig
That 2-inch thing on top is, in fact, the pcv valve mentioned earlier. You can undo the hose at the bottom of it, and check for oil in the hose; if it's oily there is a good chance the diaphragm is cracked. Another possibility is some rings stuck from sitting for two years; they 'may' free up after some more driving.
R
RonMacPherson
Or soaking them overnight(combustion chamber fill) with GM Top End Cleaner. Works great at getting the carbonbuildup off of rings.
daver80
Member
Everyone who posted- BAD GAS! drained it all out the $2.23 gas (from 2 years ago)and refilled with $4.23 gas- and all is well (except for the $4.23 part) Dave
mehheh. :laugh:
D MGB 66 MGB smoking MG 26
Kleykamp TR2/3/3A compression numbers & smoking engine Triumph 20
A Now smoking & overheated...the car folks! Triumph 17
P Horns smoking: rewire? Triumph 3
TulsaFred Bugeye smoking from the breather tube Spridgets 12
T TR6 My TR6 is smoking aka burnout or powerskid Triumph 0
Basil Is someone smoking dope? MG 16
T Help my car is smoking Triumph 7
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
Kurtis 1275 Smoking Problem... Spridgets 7
veale001 TR6 TR6 Smoking? Triumph 33
Hooper11772 OMG stop smoking already!!!! Spridgets 75
Stewart Smoking B MG 2
roofman Looking for a smoking deal! Triumph 2
MTribe 1st start after rebuild, smoking exhaust manifold? Triumph 7
Twosheds TR2/3/3A Smoking TR3 Triumph 26
hondo402000 alternator up grade and smoking dash Triumph 19
mgb4tim New server smoking! MG 14
D Smoking Generator Spridgets 20
T Bugeye smoking problem - needs a patch Spridgets 13
S TR2/3/3A TR3 Smoking Rich? Triumph 6
P I Started Smoking MG 6
jaybird Somebody's smoking crack MG 11
B What's this cat smoking???? Austin Healey 24
B Just Installed Rebuilt Generator - It's SMOKING?! Austin Healey 8
T smoking engine Jaguar 8
G Smoking like a chimney - but only sometimes Triumph 9
J Continued from... "Is Smoking Bad?" Lotus 4
J Smoking is that Bad? Yeh Sure, Help.. Other British Cars 12
H Still smoking! Triumph 4
J Smoking BN2 Austin Healey 14
bighly Smoking exhaust after warm-up Austin Healey 13
B For Sale MGB Parts MG Classifieds 0
G MGB-GT 1968 MGB GT 1800 AUTOMATIC MG 0
G MGB-GT 1968 MGB GT AUTOMATIC MG 2
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
H MGB 1980 mgb no power from ignition switch MG 23
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
C MGB 1980 MGB Roadster Tyres UK MG 0
AngliaGT MGB What Did You Do on Your MGB Today? MG 6
Y MGB Pitfalls and cans of worms regarding MGB flywheels MG 12
drooartz MGB Securing MGB to a trailer MG 6
mch979 1967 MGB GT bonnet issue MG 25
drooartz MGB Made a decision, my MGB is going... MG 58
6 Seeking 1967 MGB roadster in good driving condition MG Classifieds 3
Riggsp MGB New to me MGB MG 18
Dontyler MGB-GT Sorting my new 1970 MGB GT MG 12
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
