Sliding bottom windshield seal into groove...
MGNoir
** Edit **
You know how it goes. You post a question, which makes you think more, and you solve your problem. See my solution/answer at bottom of post...
I'm replacing the glass and seals on my windshield, and am somewhat stuck on sliding the bottom seal into the dovetail groove on the bottom. Even with some judicious application of lubricant, I can only get it on about half way before any progress is measured in 1/16"-1/8" increments
A) Should it really be this hard to do?
B) Any suggestions?
Fortunately the seal provided (ala MOSS) is much longer than necessary, so I can grab one end with a vicegrips. I had been wondering about tying down the other end and to essentially stretch the whole piece to make the rubber get smaller. That said, I keep thinking either there's a special tool, or it's just not supposed to be that hard.
** ANSWER **
Use far more dish soap in the track and on the rubber piece than you think you need to use. Also a vice grip to hold onto the end of the rubber piece helps immensely (as long as it doesn't slip off).
Jim_Gruber
I took the windshield apart on my '68, undid the 6 Posaidrive Screws, slide out the old rubber and slid in the new. I used an impact screwdriver to get the screws ubnstuck with a Posidrive Bit and it was no big deal. BE Windshields are different. YMMV on htis one however and removing those screws is at your own risk. Plenty on PB Blaster ahead of time, Posi Drive Bit and the Impact Screwdriver did it for me.
Agrandshort TR2/3/3A Sliding yoke Triumph 11
M T-Series MG TD 1st/2nd sliding hub end play MG 1
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
T Tires for sliding her around Triumph 11
coj Longbridge Sliding Top Austin Healey 13
D first gear sliding hub play Austin Healey 10
T source for webasto sliding tops Triumph 3
red_tr250 GT6 Sliding Roof on a GT6 Triumph 2
N grease for rear axle sliding joints Triumph 14
ncbugeye Sliding sidescreens Spridgets 16
D steering column sliding Triumph 9
A keeping choke from sliding back in Austin Healey 28
C MGB Re strapping a MGB seat bottom MG 2
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
drooartz MGB Talk to me about bottom end bearings MG 34
S TR2/3/3A bottom of the grill screws Triumph 3
D Wanted BN1 LH Seat Cushion [Bottom] Austin Healey Classifieds 0
B Wanted WTB: TR3 Late model-"Round bottom" door Triumph Classifieds 4
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
J front cross member height from bottom to floor on BJ8 Austin Healey 5
S TR2/3/3A old seat bottom Triumph 9
P TR2/3/3A TR3A Seat Bottom Rebuild Triumph 8
A TR2/3/3A bottom gearbox cover with HDVA conversion Triumph 14
R TR2/3/3A Door bottom seal Triumph 10
M BJ8 radiator bottom hose Austin Healey 31
P TR2/3/3A Figure 8 gaskets at bottom of liners Triumph 4
M TR4/4A windscreen frame bottom rubber seal......help please. Triumph 3
S TR2/3/3A bottom out the trunnion Triumph 7
Tinkerman TR2/3/3A 1960 TR3A Bottom Rubber Seal on the Windscreen Triumph 3
K TR2/3/3A Brake Resevoir bottom Fitting that Connects to Pipe? Triumph 4
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
J TR2/3/3A Hood lift to front apron, what size are the screws that go from bottom up? Triumph 10
S Seat bottom identification Austin Healey 1
DanLewis Correct hose from water pump to bottom of radiator? Spridgets 3
J Replacing back of the boot and two bottom corners Spridgets 3
DNK Sore Bottom MG 7
DNK TR6 TR6 Bottom hose Triumph 5
T TR4/4A 1963 TR4 project Possum Bottom Triumph 5
tmc TR2/3/3A Top and bottom windscreen trim - TR3A Triumph 10
T Gas leaks from the bottom of my Stromberg carbs. Triumph 7
L Bottom end of the market Austin Healey 15
6 noise from bottom of engine... Triumph 10
Jim_Gruber Bottom Starter Motor Bolt - How do I get it loose? Spridgets 7
BugeyeNJ58 Carb leaking HS2 at bottom of float chamber Spridgets 21
G bottom rubber windshield fit Triumph 11
J TR2/3/3A Will flatbed truck scrape bottom of TR3A ? Triumph 13
