single pole or double pole?
Steven
I'm going to replace my heater/blower switch for a 75 TR6, and since it has a 2 speed, center off setting, would I need a single pole, or a double pole toggle switch for the replacement?
S
Steven
Thanks Alec....I believe there are 2 or perhaps 3 wires that connect to the original switch. The fan would require a low/high with an off setting. I only mentioned the center off toggle because i had another car that had that kind of a blower switch configuration. The original switch isn't available anymore. Buying a used electrical switch over the net is too much of a crapshoot for me to mess with. NAPA has quite a few selections of toggle switches so I guess I'll have to take my original in to them to match. The original was a push/pull type switch.
[ 02-16-2004: Message edited by: Steven ]</p>
PC
I am not specifically familiar with the Triumph's wiring but it sounds like what you are talking about is a single pole, double throw, center off switch. Sometimes they are also called, SPDT on-off-on.
This is a common configuration for electronic switches and is typically used when a device has two inputs and you are selecting whether one input, the other or neither is connected to something.
PC.
G
Hey Steven,
As far as switch availability, I personally would put NAPA about third on my list when looking for electrical make-do switches. I have found that a marine electrical store to be an excellent first choice (of course, I live near the Gulf of Mexico with lots of oil field service companies in the area). Their quality is top drawer and many of the switches are made in England. Good stuff and oft fits Triumph bezels and switch plates. Next choice would be Radio Shack as they obviously specialize in electrical and have a better selection...
Bill
G
Addendum.
I wired some Cibie fog lights on my TR6 using these British made SPST internally lit rocker switches and they PERFECTLY sit where my seat belt warning light once resided. Their relays are also British and are super quality
Bill
S
Steven
There are not too many marine shops here. I've heard Radio Shack might be ok, and we do have one of them. Thanks for the suggestion Dr. Bill.
piman
Hello Steve,
basically if you switch one line that is single pole, two lines two pole, three etc.
Your switch is unusual in being centre off, but if you can't find an original switch you could think about using a side\headlight toggle switch as used by many cars, even Mini's if I'm not mistaken. That will however be an Off/slow speed/high speed rather than centre off.
Alec
C LCB header with 1500 single carb inlet manifold Spridgets 1
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
shadowfever Single SU on Spridget Spridgets 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
AUSMHLY 65 BJ8 Front Single Lamps Austin Healey 35
steveg Switching multi-wire wideband O2 sensors between single gauge Austin Healey 11
K WTD Single SU Manifold for AH Sprite Spridgets 0
R 1275 engine with SU HIF single carb Spridgets 9
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
drooartz Single stage vs base/clear Spridgets 29
M TR2/3/3A Single brake light modifcation Triumph 2
W Single Minator wheel available Spridgets 3
N DCOE double vs. single choke theory Spridgets 11
Foura TR4/4A TR4A Exhaust - Twin or single? Triumph 8
Scott_Hower 1500 single rail gearbox rebuild? Triumph 7
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T Wedge The Wedge Shop Single Turbo TR7V8 build Triumph 3
T building a single tower Sprite storage lift? Spridgets 21
J Bugeye single piece top frame same as two-piece? Spridgets 4
B Spitfire big bearing snap rings on Spit single rail Triumph 0
B Spitfire That Spitfire single rail gearbox again Triumph 2
N Convert BJ8 exhaust to single silencer Austin Healey 6
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
G Spitfire Anyome here running a single DCOE on a Spit? Triumph 0
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
bigjones Single HS4 on a 1500 Spridgets 25
Stinger Stag TR4A Paint BRG #25 Single Stage or Base Coat Clear Triumph 13
L Two screw or single bolt side view mirrors? Austin Healey 8
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
Ofcalipka Zienith single carb problems. Spridgets 34
Ofcalipka Zenith single carb problems MG 62
T Triumph Spifire - single rail gearbox sychro Triumph 0
M Help with single SU on midget Spridgets 19
bighealeysource single 12 volt battery conversion on a 1954 BN1 Austin Healey 9
germanmichel Capillary tube of oil/temp.-gauge as single part ? Austin Healey 8
dklawson Spitfire Spitfire - Single-Rail Gearbox Frustration !!! Triumph 20
dklawson Spitfire Spitfire Gearbox Swap - 3-Rail to Single [Parts?] Triumph 2
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
58Custom Anybody have schematic for single transistor tach? Spridgets 6
B single stage PPGpaint for Healey Austin Healey 15
beaulieu XK 120 Batteries - single 12v or pair of 6v ? Jaguar 7
T Single rail transmission Triumph 1
DART Huffaker "single hoop" MGB Racing 1
C Intake for single SU Spridgets 10
Aldwyn Single Headrest? Triumph 7
Randy Forbes Single [double jet] windscreen washer questions... Austin Healey 7
mgbmedic Single Zenith Carb- Results MG 1
