side curtains for longbridge 100-6
Just about to give up trying - anybody know how to find a set of side curtains for a longbridge built 1958 100-6 healey? It's like searching for the holy grail
Looked there - the Longbridge built 100-6 has a slightly different set of mounting brackets, and the curtains are a little bit smaller. When a vendor just specifies 100-6 BN4 they usually mean the regular curtain from the non Longbridge models. Thanks
Thanks, I check in on E-Bay daily. For your dual jet, try www.holden.co.uk and type in under their product search "washer jets, tubing & fittings" and you'll find four or five types, including a dual. Good luck!
I believe that you cannot get them anymore new. However, some of the parts which were originally on the Longbridge model are available from www.sc-parts.co.uk as well as www.ahspares.co.uk. regards --- Higgins
None of those look like the original Trafalgar dual jet, but I am using one of this type till the elusive original shows up. I found two of the washer jars, and if I can find those, the jet will come one day as well. (the other is spoken for before you ask)
Patton
[ QUOTE ]
[/ QUOTE ]
