shock fluid
WLJ
Member
Just finished installing two rebuilt stub axle/kingpin assemblies on my 75 b. Not a hard job but a bit pricey! I also removed and cleaned up the shocks. I was wondering what is the best type of fluid to put in the shocks for a good handling but not overly harsh ride?
Warren
Kim de B
I've heard people use motorcycle shock oil or mineral oil, but haven't had to do mine, so have no first-hand knowledge.
Rick
Member
Hi,
If you follow the recommendation of the Bentley Workshop manual, it recommends to use Armstrong Super (Thin) Shock absorber Fluid No. 624 or any good quality mineral oil to specification SAE 20W. It also mentions that the 20W mineral oil is not suitable for low temperature opration, but does not define "low temperature".
Tintinmilou
Member
I've used: hydraulic jack oil, motorcycle fork oil, and 15 weight motor oil. They all seem to work equally well.
The Motorcycle fork oil has the side-benefit of having seal-sweller additive, which helped my shock leak less fluid. It's also the most expensive. But a quart of oil will last you a very long time.
After a few years of maintaining leaky front shocks, I finally replaced them.
G
I use 20wt motorcycle shock oil and have been pleased with it.
G
I have had good results with mineral oil. If it was empty recheck after riding awhile or disconnect shock and work up and down to make sure all the bubbles are out.
C MGA Shock fluid MG 14
RJS TR4/4A Lever Shock Fluid Level Triumph 1
stretchit2 Hydraulic Shock Fluid - Bilstein Shock Conversion Austin Healey 6
John_Mc Lever shock fluid Triumph 19
G Checking & filling shock absorber fluid Spridgets 9
T TR4/4A Early TR4 - Lever Shock Absorber Fluid Triumph 2
G Right-Side Shock Weeping Oil Austin Healey 1
G Squeaking Armstrong Shock Absorber Austin Healey 7
Celtic 77 General MG Lever shock oil refiller MG 0
M Left shock Spridgets 4
Gliderman8 TR6 Lever shock noise Triumph 18
RJS General TR Lever Shock - HD Shock Valve Triumph 2
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
Boink Ugly Shock Failure Spridgets 3
H Shock absorber conversion Austin Healey 3
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
AH67AH Broken Shock Mounts Austin Healey 23
H Rear Shock Removal Austin Healey 5
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
Got_All_4 TR6 Armstrong Shock Colors Triumph 3
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
J Thread Locker on Shock Bolts? Austin Healey 19
AUSMHLY Lever Shock Oil Level Austin Healey 41
M e-type siries 1.5 shock abosorbers Jaguar 3
O Shock Absorber maintenance Spridgets 4
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
trotti Shock mount problems Austin Healey 9
S TR2/3/3A rear shock arms and links Triumph 4
Raymond General Tech Shock oil MG 4
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
John Turney Left Rear Shock Mount Austin Healey 5
R Shock Absorber Austin Healey 0
Griz Shock failure Austin Healey 4
S TR6 TR6 shock links Triumph 10
G TR4/4A Front Shock Install Triumph 14
G BJ-7 Rear Shock Link Austin Healey 2
wkilleffer MGB Armstrong shock oil- 20W oil? MG 6
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
I 1954 BN1 - Bump Rubber [shock stopper] wrong length?? Austin Healey 8
T TR2/3/3A How important are matching rear shock links? Triumph 9
maxwedge5281 front shock absorber mounting Austin Healey 3
Sarastro TR4/4A Shock aborber recommendations Triumph 6
T Tube shock conversion BJ8 Austin Healey 6
