Shake down run
Stewart
Well it was time after all the work I've done on the 73. Cars actually pretty comfortable on the highway and killer in the twisties.
Stewart
Stewart
Time for the return now to decide if I go back the way I came or head up through sturgis and then north from there back to nd. Hmmm
Stewart
Stewart
Went through sturgis and about 200 miles of rain. Cars still running great and I stayed pretty dry only a few drips here and there. Little over 370 miles to go with 1000 miles done.
shadowfever Shake down run Spridgets 2
tomshobby Shake down tour Spridgets 6
WillR MGB First shake down. MG 3
Brosky 35 mile shake down cruise Triumph 20
DNK Wedge TR8 Shake down cruise Triumph 11
craigshealey3000 Front End Shake Austin Healey 31
steveg Steering column steady brace and scuttle shake? Austin Healey 2
M Scuttle shake. Austin Healey 16
D Scuttle shake and tyre pressures Austin Healey 2
B Scuttle shake finally sorted Austin Healey 23
PAUL161 T-Series Scuttle Shake/Vibration MG 6
S Scuttle Shake Austin Healey 95
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
NutmegCT TR2/3/3A TR3 shake Triumph 8
5 The scuttle shake mod- I can't decide Austin Healey 7
L Balancing wheels and cowl shake, part 27 Austin Healey 5
Anthony_S TR2/3/3A TR3a slight shake at 60-65 mph Triumph 8
D whats causing my SCUTTLE SHAKE !!!! Austin Healey 39
richberman Scuttle Shake solutions, necessary? Austin Healey 24
S TR4/4A TR4 front suspension shimmy and shake Triumph 8
PATR8 Wedge TR8 shake and shimmy resolved Triumph 7
I TR6 TR6 Shake, Rattle and Roll Triumph 18
B shake RATTLE and roll Spridgets 2
J What is scuttle shake and is there a cure? Austin Healey 9
malice Distributor Shake Rattle Roll Triumph 23
RickB Shake, Rattle & Hum... CONTEST!! Spridgets 111
J Do BJ8's suffer from skuttle shake? Austin Healey 7
Randy Harris Scuttle shake at 55 Austin Healey 20
Brosky Bad steering wheel shake over bumps Triumph 13
R cowl shake Triumph 5
Dave Russell Front End Shake at Higher Speeds Austin Healey 5
C Front End Shake at Higher Speeds Austin Healey 5
C BN6 Front end shake at high speeds Austin Healey 7
C Rattletrap [ Scuttle Shake ] Austin Healey 46
J "wait for the shake" Austin Healey 7
Patton Shake Rattle and Roll Austin Healey 8
B Will fixing Healey Shake negatively affect Resale? Austin Healey 6
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Got_All_4 TR6 TR6 Down Pipe How They Last Triumph 6
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
M MGC New book: MGCs Down Under MG 0
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
Busted knuckles TR2/3/3A Engine tear down, Triumph 13
Rut Cut down windshield Spridgets 22
S TR2/3/3A trim to hold down the furflex Triumph 3
Sopwith_Camel up or down? Jaguar 12
