Series III XJ-6 4.2 Liter Cylinder Head removal
Michael J.
I have the Acorn Nuts removed and the six smaller nuts around the front of the head removed.
Penetrating oil easily sinks around all but two of the head studs, but the head will not budge.
The replacement cylinder head gasket is composite with what appear to be steel rings for the actual seal.
The head protrudes about 1 1/2 inches on each side hanging over the block. I tried a small two ton bottle jack with a small wood block pushing up against the over hang, but it will not budge. I did not have this much trouble pulling V-12 heads. Is it always this hard to remove the six cylinder head?
Is there a secret to this?
mikespain
The problem is that the head studs sit in the engine coolant,and seeps up the stud and rust and corrodes the stud bore and bonds it to the stud can be really difficult to remove the head.Perseverance penetrating oil and a lot of pushing shoving and rocking it should begin to move,try leaving it with pressure on for a day-or more!When it does eventually come off the studs should be replaced,the last thing you want is to hear "PING"when the stud breaks as you do the last torque pull down! Good Luck
jessebogan
Be really careful removing the studs.They screw into the block near the crankshaft. Most of them can be accessed by removing "freeze" plugs. I would reccommend knocking out the plugs, and directly soaking the threads in the block, and maybe a little heat before removing them. A little time and patience spent before beats the you-know-what out of removing the block to get it drilled out by a machine shop. If you are clever and handy, make a head pulling plate. Attach the plate by the spark plug holes. (The one I have used has the metal ends of spark plugs welded to the bolts for a perfect fit)Drill and tap holes that correspond to the head studs, and evenly turn the bolts down against the studs. This will pull the head off. I know that British Parts International makes one for V12s, and it might be worth checking if they have one for 4.2s
Good Luck
LarryK
It takes time! Keep your cool and use the penetrating oil, pull, rock, etc. Let sit try again. Use some spacers each time the head moves up to keep it from dropping. A second set of hands helps as then you can work from both ends at once. Since you should replace head bolts, you can remove them which, if they do not stick in head will help.
KeithHodges
As several have mentioned, it takes time. There are lots of posts about this on Jaglovers.org. I read one post where one member kept pressure on with a couple of jacks for 3 weeks before it finally popped loose. Patience is far better than stud removal at a machine shop. Sorry, but theres just no easy way. Most of these cars are close, or past the twenty year mark, with alot of miles, so a little patience is nothing compaired to what it took to get in that condition in the first place. Good luck. Keith Hodges, 85 XJ-6, 95 SJS 2+2 Conv, 6.0 V-12.
M
Michael J.
It finally came loose after soaking the studs twice per day for a couple of weeks with PB Blaster and using 4 bottle jacks, two on each side, to keep it under pressure. I have it being cleaned and inspected for condition to see what parts are needed at a local shop that has done a number of Jag engines over the years.
It was almost as hard walking it up the studs to get it off.
KeithHodges
Way to go. I love hearing success stories like this. Patience is the best virture there is. Congrats!. Keith
Platinum
Late as usual... BPI did have a plate for the sixes a decade back. Likely still do. If you do this job more than once a year or intend to keep the car it's worth every penny, too.
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
D Series III E-Type Overider Rubber Installation Jaguar 2
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
J Question about Series III XJ6 Motor in E Type? Jaguar 2
toysrrus Series III Rdstr. Top Bows [Grey] & Vinyl [Blk] Top For Sale. Jaguar 4
D XJ6 series III front end rattle Jaguar 5
D Series III side marker to blinker conversion Jaguar 2
M 87 Series III XJ6 Rough Running Jaguar 16
Bruce Bowker Series III E Type Jaguar 9
M 87 Series III XJ6 won't Start Jaguar 16
M Looking for a E Type Series III Bell Housing Jaguar 1
Sprocket Series III factory service manuals - $50 Jaguar 0
M Alternator or Battery Problem on 87 XJ6 Series III Jaguar 5
M Tricks for Alternator Removal 87 XJ6 Series III? Jaguar 8
wkilleffer Series III XJ6 a/c amp questions Jaguar 1
bmurphy7369 Late Series III motor/FI into a Late Series II XJ? Jaguar 5
bmurphy7369 Need some rust repair advice for Series III XJ6 Jaguar 8
S Easiest way to disconnect Tach on XKE Series III Jaguar 4
S Bouncing Tach on Series III E-Type Jaguar 4
P Correct steering wheel for Series III Sunbeam (Rootes) 3
G Series III E-Type problem to look out for Jaguar 1
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
O Wanted Vauxhall Victor F series parts Other British Classifieds 2
O TR6 TR series transmission compatibility Triumph 4
