• Hi Guest! Being a Paid Subscriber is NOT required to participate at BCF. However, if you enjoy BCF and find our forum a useful resource...
    Please consider supporting us by **Upgrading**
Screaming "Chain"
Dave Richards
I got to open the Healey up a little bit on the back roads with the other LBCs at the Vintage Grand Prix two weekends ago.
I really enjoyed myself and I think the car did too. /ubbthreads/images/graemlins/driving.gif
One of the other drivers, that I passed, mentioned that I really had a “screaming chain” in that engine. On reflection, he’s onto something.
The car has 56,000 miles; I’ve been through the car, over the winter, with a very experienced mechanic who also has considerable racing experience. We’ve adjusted the valves and it sounds and acts pretty tight. However, at “speed”, say 70+ MPH or so, with the tach flirting with the mid-range of the yellow zone, there’s a screaming chain noise. It’s reminiscent of the chain noise the Volkswagen beetles used to make, but much higher pitched and much faster.
Oil pressure runs just under 60 lbs, hot, with 10w50, compression tests, earlier in the year, were all about 120-125, as I recall.
Can anyone shed any light on this?
Keoke
Can't put a spot light on it, But FWIW:
Timing chain oiler misadjusted/partially blocked
Timing Chain Damper Worn
Timing chain Tensioner Worn
Timing Chain worn
Crank shaft oil thrower Reversed or spinning on shaft
---------------------------------------Keoke ??
R&M
Dar100/Jedi
We were at the Vintage GP in the Glen also. Have been at every one since it started.
Which Healey was yours? Color Etc.
We had the 67 3000 Red over Black with Heritage interior and sunfast top. Stayed at Glenora Inn.
Will look for you next year.
Sorry to hear about problems. May they be minimal.
Regards,
R&M
Orchard Park, NY (Yea I know "Home of the losing Buffalo Bills) /ubbthreads/images/graemlins/driving.gif /ubbthreads/images/graemlins/driving.gif
Dave Richards
Dave Richards
R&M,
Red BJ8, all original, ran the Knapp vineyard "tour" It was at the first stop that the high pitched noise was mentioned as described above.
Was at the "antique" auto show at the track, between a beautiful black 100 and a nicely restored red 3000 from PA., I think.
Beautiful weekend.
Thanks Keoke, I'm hoping I won't have to get into the engine until the long dark winter...
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
S This is screaming my name! Other British Cars 1
jackq screaming alt. MG 6
78Z Screaming Minis British Motor Corp 2
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
D TR2/3/3A Timing chain tensioner. Triumph 3
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 7
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
Drone Dog BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
R General Tech Timing chain replacement Triumph 5
RJS TR4/4A Timing Chain Oil Seal Triumph 6
D TR4/4A how hot does the timimg chain cover get? Triumph 15
B TR2/3/3A Timing chain cover goop location Triumph 4
B Timing chain tensioner help Austin Healey 15
G Timing Chain - Slackend Austin Healey 5
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A timing chain cover and woodruff key Triumph 4
G TR4/4A timing chain and sprockets Triumph 9
DanLewis Looking for a good timing chain cover Spridgets 1
BlueMax Wiper Chain Tubes Spridgets 3
B Timing Chain Tension Ring for BN2 Austin Healey 2
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
RJS Timing chain oil seal Triumph 12
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
TulsaFred Timing chain Spridgets 22
6 timing chain sprocket Triumph 5
Darrell_Walker Timing chain tensioner wear Triumph 8
6 timing chain cover Triumph 4
hymodyne TR6 TR6 dual chain sprockets Triumph 3
bugedd Anyone have a timing chain cover? Spridgets 10
rikiwho123 timing chain to gear drive? Triumph 4
eschneider TR2/3/3A TR2/3/4 timing chain tensioner Triumph 4
M TR4/4A tr4A timing chain procedure? Triumph 9
c5racer 1500 Timing Chain Upgrade to TR6 Spridgets 1
W TR6 TR6 Timing chain oil seal question Triumph 3
