X
xsteamer
Well I've known for awhile that the passenger door hinges were suspect because I had to lift the door slightly to close it. We went on a run the other day and wife mentioned that it was getting worse. Sure enough, I can lift the door a good inch before it matches the door latch. Most of the play would seem to be on the bottom hinge inside the door. Before I rip it all apart maybe our body gurus can chime in. Is there adjustment, ie bolts on the hinge inside the door? Any solutions would be appreciated.
