apbos
I finally got the 1959 B/E in the garage and began taking it apart, labeling and taking photos. I believe I don't have the orginal motor in the car as the head is painted red. I also can't ID the carbs, intake manifold and the heatshield configuration. The shield has been modified, I think to allow an after market header. https://www.flickr.com/photos/13206219@N07/2147576789/in/photostream/
Secondly, I'm just about ready to move under the car and would like to know where should I place my jack stands so I can disconnect the trans etc. I plan to remove all the bits and then use the plywood roll over frame I've constructed. What should I do to be safe while working under it? Not much room if it comes down on you. The adventure begins!
Paul
Paul
