RX7 rear axle ???
nomad
Just curious about fitting an rx7 rear axle to a spridget. Are there any tech articles on this??? Know that a 81 to 83 axle is preferred. I can get a 84 which, according to wikipedia, has a different wheel bolt pattern than the earlier axle. Mainly wondering if the earlier pattern is 4 inch and will bolt up to spridget wheels and how much work is required to narrow the axle?
Kurt.
Jim_Gruber
Kurt, I may be wrong but I think the guy that built The Mite used an RX-7 Axle. Google The Mite if you've never been there before. He used something to keep the turbo Miata engine from breaking rear axles. Maybe he adapted a Miata Rear End and a 4 link. Now I've got to go back there and look.
aeronca65t
There is a guy on the MGExperience that is going to narrow a ford 7.5" since they are cheap and have a wide range of gear ratios. I think he said the shortened axles were going to cost $300, but when he is finished he'll have LSD and disc brakes. He said he'd try to weigh it when he gets it finished.
Westfield_XI
Follow the link in the article on the Mite to Moser and give them a call. They have probably done this conversion several times before. This sort of work is their speciality.
N
nomad
Thanks much folks, I've been busy or would have been back quicker. Just daydreaming about building a spridget with a lot more power. Knew I had seen some of that stuff here before. Wish I had a lathe!
Kurt.
regularman
I wonder if it has to be an rx-7 diff. I is it that much tougher than others? Some of the Mustang II models with the 302 engine had the 9 inch rearend, as did a few with the V6(my 74 model did). I also have a Kia sportage and it has a pretty marrow rearend with a solid axle in the back and weighs in at about 3000 pounds with a 2 liter engine and has been through hades and no diff problems.
N
nomad
I imagine it could be a lot of different axles but the RX7 axle has limited slip and disc brakes and is light and tough. One has to consider unsprung weight or handling will go away. I know of a bugeye with a hot rotary and a 9 inch ford rear that goes like stink in a straight line but gets whooped in autocross.
Kurt.
apparently, the gearing of most rx-7 diffs is somewhere around 4.11
N
nomad
Ah, good call, Trevor. The Mazda wankel would be a high revving engine which would explain the low rear gears. So would the ford be light and make for a good swap? How about other suggestion's--someone mentioned a rear axle from a Subaru. Early 80's is getting pretty old for japanese stuff. Nissan at least does'nt support any of the old stuff. The guy with the bugeye that a friend told me about may have other handling problem's. Higher unsprung weight should only be a factor on rough surface's.
Any pictures from the MG experience guy? I'll see if I can find the site.
Kurt.
He hasn't made the swap yet, but based on his other work ... it'll get done and he'll post pictures.
JPSmit
I haven't seen Phil on the site recently but he runs an RX7 rearend on his Sprite.
regularman
Kurt.
The Subee would be an independent rear. That gets a a lot more complicated. I am trying to think of something that might work and have a higher ratio, yet still be light.
bugedd RX7 rear axle and brake question Spridgets 2
bugedd Limited Slip advice, scrapping idea of RX7 rear end Spridgets 34
B RX7 Rear End in a Midget Racing 3
Rut RX7 key fob Spridgets 6
T Any pictures of Rx7 E-brake cables? Spridgets 6
Healey Nut Rear Wiring Routing Austin Healey 2
R TR6 Rear suspension droop restraint Triumph 0
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
drooartz Rebuilding rear axle Spridgets 10
S TR2/3/3A rear main seal is leaking Triumph 13
J TR2/3/3A TR3 Rear seat Triumph 11
T crankshaft (rear) bearing leak Spridgets 2
G For Sale: Triumph TR2, TR3, TR3A, TR3B Factory Steel Hardtop, New Rear window, Partial Bracket Set Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
5 TR2/3/3A Seized rear brakes Triumph 9
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
S Rear Wing Fit Austin Healey 4
chicken BJ7 Rear Quarter Panels Austin Healey 3
M For sale rear wings Tr6 Triumph Classifieds 3
Healey Nut BT7 Rear Suspension Austin Healey 15
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
M Have a pair of tr6 rear wings Triumph Classifieds 0
D MGB Rear Suspension Damper Link Arm MG 2
S Rear End Noises Spridgets 11
Jeepster Rear Brakes Adjustment Austin Healey 6
M Wanted TR6 Rear Bumper impact Brackets Triumph Classifieds 0
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
E TR6 74 TR6 - Rear and windshield frame color Triumph 2
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
8 BJ7 Rear rail trim Austin Healey 0
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
G Rear Brake Adjustment Austin Healey 30
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
vette MGB Rear Fender Dog Leg Patch Panel MG 3
Martinld123 My left rear wheel is locking up Austin Healey 16
R TR2/3/3A Girling Rear Brakes Triumph 9
J TR6 Differential / Rear Axle Triumph 1
G Noisy Rear Hubs Austin Healey 6
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
PAUL161 MGB Early B Banjo Rear Gears MG 2
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
H TR2/3/3A rear apron Triumph 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
