Running rough
vping
Morning all,
Thought you guys might be able to help on this one. About a week ago, I decided to change the oil and adjust the valves on my '74. Last time I did the valves was over a year ago and they were starting to get noisy. In a nutshell here is how that morning went.
Drained oil
Removed valve cover
Turned over engine by bridging wires on Passenger Fender relay (here is where my problem might stem from) to adjust all valves.
Pulled plugs and checked compression which was 1-125, 2-130, 3-125, 4-125
NGK BPR6EGP - All plugs were a nice light-ish brown gray but #3 had a mineral deposit of sorts on it. I picked it off with my nail but it was hard stuff and thick.
Replaced Valve cover then oil then filter.
Keep in mind that other than noisy valves this car runs (ran) like a top and is a rocket for a stock engine (with a PECO). Never a burp never a hiccup - starts without choking even in winter.
I run a one of Jeff's 25D's with Pertronix. One of three I had him build for me. In fact I should send him two more.
Started it up and she ran quietly.
All is well until I drive it. I can barely take off from a stop without it sounding like it is running on 3-cyls. Bogging and sputtering but then it kicks in fine. At higher speeds it runs like a top again. I checked and replaced the #3 plug and it still runs rough and I when I did I noticed that all my plugs are black and sooty like it is running really rich. Tailpipe is also sooty and it was not before. I've driven it about 100 miles this way to see if I can blow out anything that might have changed as a result of my service.
My fear is did I partially damage the Pertronix by trying to turn over the engine using the relay? Should I look elsewhere and is using the relay this way a bad idea?
Should I check the valves again?
Cheers
Vince
BoneIdle
Have you checked the carburetors yet? I had a float problem that produced the same symptoms of which you speak.
Mine would idle fine, then sort of conga down the road. At highway speeds it was relatively smooth ( i.e normal except for an occasional burp). Once I manfully ripped the carburetors off the engine, I discovered that the rear float was way out of adjustment.
Just a thought.
bgbassplyr
Check the valves again. Quiet when cold might equate to too tight when hot. Can't hurt to check. Might try getting engine hot, pull the cover and check the clearances hot while running. This will beat up the feeler gauge but if you can move it with the engine running, clearance should be good.
PAUL161
Vince, you didn't say what you set the valves at. I always set mine at .015 (static) to start and then work from there. I might be wrong, but I don't think the Pertronix electronic ignition would be damaged by bumping the starter to rotate the cam. If the engine ran good before you adjusted the valves, then unless one of them is too tight,(a strong possibility), it should run as before. Just a suggestion but, I'd reset them to .015 and run the engine again. If alls well, one was set too tight. PJ
Roger
Bronze
You're unlikely to have hurt your Pertronix. They get damaged by being left with ignition on and motor not running for several minutes or longer.
It sounds like you're running rich, but you don't mention carburation. Most people can't resist doing something carbwise - you didn't touch anything?
You might re-check your clearances as suggested above, but the fact that it runs ok at higher speeds doesn't indicate you have a clearance problem.
I do find it odd that it has a noisy valve problem and you adjusted them a year ago or so. How many miles do you do between adjustments? Any idea why the gaps are opening up - I assume that's what's happening?
vping
vping
Valves are set at .015". The engine sat for 12 years before I got to it and I did virtually nothing the the engine itself. I really got lucky with it. I decided to re-set the valves as running it for the past year or two, things may have settled in seeing is that it sat for so long unused. Who knows what kind of rust or build up was there.
I believe I found the problem though and it may be a result of starting it with the relay. There was a burned spot on the rotor and each lug of the Dist Cap. I cleaned them off and she started much nicer. I'm taking it on a test drive tomorrow to see how she does. Maybe there is some residual current traveling through that caused this. Whatever it may be, the test drive tomorrow will tell the story.
vping
vping
Still NG. I ran it to work this morning and it sputters in first. Intermitant too. I did not check the timing after I adjusted the valves and wonder if that had an effect on my timing.
Roger
Bronze
It might help if you told us how you adjusted the valves - I mean what method you use to ensure you adjusted them at the proper position.
vping
vping
Adjusting the valves was by using the rule of nines and at .015" I'm sure this is fine.
So I decided to swap out the cap and rotor with a used set I had from a dizzy that was sitting on the shelf. Runs like a top again. Not sure what happened to the cap and rotor but all is well now. Go Figure?
Vince
T TR2/3/3A rough running after 20 min shutdown Triumph 9
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
N Stuck Needle Valve - Rough Running Austin Healey 15
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
D Rough running BT7 3 carb HELP Austin Healey 13
B Thoughts...rough running at cruise. Austin Healey 3
GTP1960 TR2/3/3A Rough running / a lot of carbon on the plugs Triumph 11
K TR2/3/3A Dead Petronix and rough running..... Triumph 10
I BJ8 is running a bit rough. . . Austin Healey 7
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
M Rough Running 99 XJ8 after Overheating Jaguar 42
T TR2/3/3A TR3 Running Rough - Cause[s]? Triumph 8
K TR2/3/3A TR3 Running Rough Again? Triumph 7
bighealeysource BN6 runs rough on restart after running great Austin Healey 7
M 87 Series III XJ6 Rough Running Jaguar 16
G Rough running and backfiring MG 30
M TR2/3/3A Another rough running TR3 Triumph 1
T TR2/3/3A TR3 running rough Triumph 6
bighealeysource Up-date on engine running rough on my BN6 Austin Healey 1
A rough running after long idle or long low rpm driv Triumph 1
R TR2/3/3A TR3 Missing [running rough not stolen!] Triumph 4
tahoe healey surging and rough running Austin Healey 20
K TR2/3/3A TR3 Running rough..Cam or Carbs?How to diagnose? Triumph 10
H MGB-GT Help with my 1967 MGB GT running very rough MG 5
R TR6 Rough running TR6 = Pertronix? Triumph 27
Woodie rough running Spridgets 7
S TR2/3/3A Rough Running TR3A - help with diagnosis Triumph 11
A TR4/4A TR4A running rough question[s] Triumph 11
Woodie missing, running rough etc etc Spridgets 25
J running rough / missing Spridgets 7
77MidgetMkIV Rough running at weird intervals-any thoughts? Spridgets 22
77MidgetMkIV Now running really rough-help?!?! Spridgets 15
beebopbogo Engine running really rough - 2 cyls? MG 8
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 0
sparkydave Trouble running hot Spridgets 7
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Bob_Spidell Running hot/Overheating Austin Healey 44
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
