Rough Idle
M
mgbjones
Took a nice 50 mile ride in the car the other day. Went no more than 10 miles into the ride and stopped at a stop sign and the car would not idle for crap. It sounded like it was looping. Adjusted the idle to bring it up and it still did not idle properly.
The car has plenty of power on takeoff and cruise.
Once I go home I replace the fuel filter same condition.
Checked all of the wires going to the coil and HT lead, everything was secure and no broken or chafed wires.
Pulled each plug wire off while idling the engine did not show any faults.
Replaced the distributor cap and still idles rough. Engine will start almost first turn of the key when warm. With old or new cap.
I am thinking maybe condensor or coil going bad.
I am running a Weber 32/35, Mild street cam, 25D Distributor from Advance Dist.
Since then I took the carb top off and removed the jets, idle mixture screw and cleaned everything with carb cleaner. Started the car back up and it still ran rough. Adjusted the car and still running rough. Took off spark plug wires again and all were good except 3. When3 was taken off no change in idle. Pulled plugs and they all look while or lean. Adjusted mixture to richen and still rough idle. Checked dizzy and it was a little loose and could be turned by hand. Re-set timing at about 17 BDC still has rough idle and will not maintain good idle. It seems to want to go up and down.
Any ideas?
LarryK
Don't know year but do you have points or electronic ignition? If points , might readjust. Could make rough idle if not quite right.
Mickey Richaud
Platinum
Have you checked all your vacuum lines?
And welcome to the BCF!
:cheers:
Mickey
NutmegCT
Welcome to BCF!
This is your first post here, so we don't know the engine's history. Was it running fine up until that incident at the stop sign?
Seems if it runs well at speed and under load, it's probably not the coil.
Tom
blueosprey90
Are you sure it is not just your camshaft? Looping at idle with good acceleration and power suggests the camshaft to me. Normal. Maybe it isn't as "mild" as you think. My experience limited to an MGA, but bad coil would cause a misfire in my experience. Carb problem would also cause a misfire.
M
mgbjones
Thanks everyone for you responses. It is a 1966, running points, Weber Carb, Kent mild street cam.
I am going to purchase new Points, Condenser, plugs , Dizzy cap and rotor this afternoon. Pull the dizzy and install all new parts and start from scratch. I have not really done a major tune-up in about 5 years just installed fresh plugs.
Sarastro
It sounds to me like you found the problem without quite realizing it. If you pulled off the #3 wire and nothing changed, there's definitely a problem with that wire, or possibly the plug. So, before randomly changing a lot of parts, or trying to readjust things, fixing that problem should be first priority.
Plug wires can be bad without any obvious reason--it can be hard to see a bad connection at the cap or plug. Especially if you are using resistor wires, which are notorious for that kind of problem.
So, I'd replace that wire and go from there. You might have a weak condensor or something like that, as well, of course, but first priority is the things you know are bad.
M
mgbjones
Re: Rough Idle Resolved
Well pulled the dizzy today and replaced points, condenser, cap, rotor and plugs. Once I removed the points took a good look and found a hole right in the middle.
After putting everything back together, started the car set the timing, MOWOGMAN set the carb back up and now she is running like a champ.
So what causes a hole in the points, moisture??????
Any ideas?
Mickey Richaud
Platinum
Glad you found the issue.
I seem to remember some points sets came with holes in them. Ventilation?
Or maybe the holes are in my head!
Mickey Richaud
Platinum
PAUL161
I remember them. I can not remember who made the ones I bought. I think I bought them in Pep Boys a few years back for my 54 Chevy pickup. I think they were just trying to make a set of points that didn't burn as fast. If you notice in the photo, those points weren't set properly, they had a twist in them and were only making contact on one side, something most folks never think about. PJ
Blue Streak sets were like that. Little tiny donuts. :jester:
Sarastro
Some points are made that way.They're called "ventilated points"--the idea is that air can move through the hole as they operate, to help keep them cool. I suppose it might actually do some good.
My guess is that you fixed the problem inadvertently--maybe it was a bad condensor after all. There certainly are lots of bad ones on the market. Or, maybe you have an intermittently bad connection somewhere and by moving it around, it's again solid--for now. There's still the question why pulling the #3 wire had no effect--that's the classic test to determine that a plug isn't firing.
PAUL161
My antique Ford tractor would burn the points after about 100 hrs of running. We use it to mow the fields in the areas where the big tractor couldn't go. I had to replace them twice a season. I solved the problem by putting a resister in the wire that goes from the coil to the distributor. I haven't had to replace the points in the past two years and the tractor runs perfect. PJ
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
C Rough Idle - What to check? Austin Healey 12
Robert560 Weird "rough" idle problem after ignition changes. Austin Healey 18
MGB922 Rough Idle MG 13
A rough running after long idle or long low rpm driv Triumph 1
R 1989 toyota camry, rough idle when in gear, help Other Cars 6
64rocksprite rough idle, then races to 4000 rpm?? help! Spridgets 11
H Rough Idle and Sputtering Austin Healey 22
L Tach jumping, rough idle. Triumph 9
jcatnite Persistent Rough Idle Spridgets 22
J Rough Idle-Colortune-weak spark? MG 9
T TR2/3/3A rough running after 20 min shutdown Triumph 9
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
N Stuck Needle Valve - Rough Running Austin Healey 15
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
D Rough running BT7 3 carb HELP Austin Healey 13
55modified Wanted Wanted rough BN1/2 hood for cutting up Austin Healey Classifieds 0
B Thoughts...rough running at cruise. Austin Healey 3
M TR2/3/3A Engine rough on acceleration Triumph 19
GTP1960 TR2/3/3A Rough running / a lot of carbon on the plugs Triumph 11
K TR2/3/3A Dead Petronix and rough running..... Triumph 10
I BJ8 is running a bit rough. . . Austin Healey 7
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
N Runs Rough Under Load Spridgets 15
Gliderman8 General TR Rough looking '67 Vitesse Triumph 7
JPSmit Rough Bugeye hood Spridgets 0
K Rough patch inside bore of SU? Triumph 2
W Mighty rough..... Spridgets 1
justin_mercier Post-War Other 63 Herald in rough shape, MA craigslist Triumph 2
M Rough Running 99 XJ8 after Overheating Jaguar 42
T TR2/3/3A TR3 Running Rough - Cause[s]? Triumph 8
B diamond in the rough? Triumph 6
T Rough clearance checks Spridgets 2
K TR2/3/3A TR3 Running Rough Again? Triumph 7
bighealeysource BN6 runs rough on restart after running great Austin Healey 7
M 87 Series III XJ6 Rough Running Jaguar 16
G Rough running and backfiring MG 30
M TR2/3/3A Another rough running TR3 Triumph 1
T TR2/3/3A TR3 running rough Triumph 6
vping Running rough MG 9
bighealeysource Up-date on engine running rough on my BN6 Austin Healey 1
D XJ8 rides rough Jaguar 5
D GT6 Rough GT6--your thoughts? Triumph 9
T Rough budget +/- for 1275 cylinder head overhaul? Spridgets 10
R TR2/3/3A TR3 Missing [running rough not stolen!] Triumph 4
RickB MGB 70 MGB runs rough - sputters & backfires esp. cold MG 44
