GT6 Rough GT6--your thoughts?
DaveCooper
Hello all,
I'm from the Lotus forum, been working on a 74 Elite, but I've come across a very rough GT6 at what seems like a fair price for its condition, about $1,500 USD. It's a 1970 or 1971. The seller says "1971 GT+" but I read that GT+ was only 1970 and known in the UK as MKII.
The downside is that the head (and valve cover, etc.) is missing. Otherwise, the block, intake, exhaust, etc. are all there and seem ok. Unless the block is cracked, I can handle rings and seals.
Question, what to do about the head? GT6 heads appear to be rare. Can I swap another Triumph head? I heard the TR6 head is a bolt-one, but is there any compression issue? Lot's of TR6's where I live.
Thanks for anything.
Dave
Andrew Mace
Got a commission number? Barring that, is it "squaretail" or "roundtail"? (Former would be +, latter would be Mk3.)
Shouldn't be impossible to find a head. I think TR6 heads are very similar, but I don't know offhand about interchangeability. Hopefully someone else will.
Hopefully for $1500 it's pretty good otherwise....
tdskip
Hi Dave - welcome!
Not uncommon for a 1970 to be registered as 1971, so I wouldn't sweat that too much. I've never looked for a GT6 specific head, rounding one up for a TR6 isn't overly difficult. I'd post an add or two here, on VTR etc...
Is the engine free still?
Body condition? Drive train etc?
Generally speaking, body condition is more important but if she is basically a shell as Andrew suggests it should be a solid one for $1500.
FYI - we LOVE pictures.
Keep us posted!
DNK
You can have the head out of my 71 TR6.
Ironic, the head on it now is a GT6 head.:devilgrin:
bash
$1500 does sound like a lot - I walked away from a '73 GT6 a few months ago beacuse it had rust in the floors, sills and roof. It was complete and ran, though - and that was too expensive for me at $500...
frankenstang57
I have a head off of a GT6. It's a bit rusty and will need some work. You pay shipping! $1500 does sound a bit steep for what you described. Any pics?
Number_6
Hi Dave, $1500 does sound kind of high for the condition of the car your describing. For comparison take a look at this GT6 on ebay, currently the bidding is only $306.
eBay GT6 MK3
IanF
eBay GT6 MK3
Man... if that car were closer (and I had more room...), I'd be all over it... I really want a square-tail GT6 some day... :frown:
Without seeing the body, it's hard to say if $1500 is too much. At the same time, $500 for a running car sounds cheap regardless of body condition. Again... I really wish I had more room... :frown:
Number_6
My second car was a GT6 MK3. It was my sole transport and a daily driver for about 8 years. By the time I sold it (for $250) it was so rusty there really wasn't much left of the body from the waist down.
T TR2/3/3A rough running after 20 min shutdown Triumph 9
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
N Stuck Needle Valve - Rough Running Austin Healey 15
C Rough Idle - What to check? Austin Healey 12
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
D Rough running BT7 3 carb HELP Austin Healey 13
55modified Wanted Wanted rough BN1/2 hood for cutting up Austin Healey Classifieds 0
B Thoughts...rough running at cruise. Austin Healey 3
M TR2/3/3A Engine rough on acceleration Triumph 19
GTP1960 TR2/3/3A Rough running / a lot of carbon on the plugs Triumph 11
K TR2/3/3A Dead Petronix and rough running..... Triumph 10
I BJ8 is running a bit rough. . . Austin Healey 7
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
N Runs Rough Under Load Spridgets 15
Gliderman8 General TR Rough looking '67 Vitesse Triumph 7
JPSmit Rough Bugeye hood Spridgets 0
M Rough Idle MG 15
K Rough patch inside bore of SU? Triumph 2
W Mighty rough..... Spridgets 1
justin_mercier Post-War Other 63 Herald in rough shape, MA craigslist Triumph 2
M Rough Running 99 XJ8 after Overheating Jaguar 42
T TR2/3/3A TR3 Running Rough - Cause[s]? Triumph 8
Robert560 Weird "rough" idle problem after ignition changes. Austin Healey 18
B diamond in the rough? Triumph 6
T Rough clearance checks Spridgets 2
K TR2/3/3A TR3 Running Rough Again? Triumph 7
bighealeysource BN6 runs rough on restart after running great Austin Healey 7
M 87 Series III XJ6 Rough Running Jaguar 16
G Rough running and backfiring MG 30
M TR2/3/3A Another rough running TR3 Triumph 1
T TR2/3/3A TR3 running rough Triumph 6
vping Running rough MG 9
bighealeysource Up-date on engine running rough on my BN6 Austin Healey 1
D XJ8 rides rough Jaguar 5
MGB922 Rough Idle MG 13
A rough running after long idle or long low rpm driv Triumph 1
R 1989 toyota camry, rough idle when in gear, help Other Cars 6
T Rough budget +/- for 1275 cylinder head overhaul? Spridgets 10
R TR2/3/3A TR3 Missing [running rough not stolen!] Triumph 4
RickB MGB 70 MGB runs rough - sputters & backfires esp. cold MG 44
tahoe healey surging and rough running Austin Healey 20
K TR2/3/3A TR3 Running rough..Cam or Carbs?How to diagnose? Triumph 10
A 3000 Mk III in rough condition - value? Austin Healey 21
H MGB-GT Help with my 1967 MGB GT running very rough MG 5
EastBoundJoe Engine runs rough then die's while at stop sign Spridgets 7
