Right Blinker suddenly goes out
ynotme2
Questiosn for everyone. This ewvening as I was driving the right blinker goes out. The left is okay and working fine but the right is dead. If the bulb burns out in the front or the back will the whole circuit for the right blinker stop working? Or might there be a loose connection? Also if I have to replace the bulbs, where do I go? Can I go to an autozone or special order them? Also what is the type of bulb I should get if I can get them locally at the auto parts store or home depot like place. Any ideas would be greatly welcome.
Thanks
Keoke
What blinker are you refering to.Thae dash monitor or the outside side lamp???-Keoke
Dave Russell
Yoda - R.I.P
[ QUOTE ]
This evening as I was driving the right blinker goes out. The left is okay and working fine but the right is dead. If the bulb burns out in the front or the back will the whole circuit for the right blinker stop working? Or might there be a loose connection? Also if I have to replace the bulbs, where do I go?
Thanks
[/ QUOTE ]
Usually if the front or rear goes out there is not enough current to make the flasher work on the remaining lamp. Bulbs are available at almost all auto supply stores. A standard # 1157 bulb will work in both front & rear. I personally use # 2357 bulbs in the rear because they are just a little brighter. I use the # 1157A bulbs in the front because I like the amber bulbs. They are all two element bulbs. Stop/turn & tail in the back, turn & running in the front. You can try cleaning the bulb contacts & wiring connectors first. If you have an older Healey, It is a real education to remove the lens. Working the chrome rim out of the rubber surround & getting it back in requires slowly working the rubber away from the rim as you go. There are other things that can go wrong with the turn signal relay, but try the easy part first.
RVMAN
/ubbthreads/images/graemlins/confused.gifI wasn't sure which model you had, so I had to cover the 100-6/3000's. Here are the LUCAS numbers. Autozone/Discount/Pep boys et.al. should be able to cross them to our numbers:"AUTOBOOK 726" series shows Stop/tail and Sidelamps to be all the same-(Lucas 594) "GLENN'S Austin tune-up guide shows LUCAS 380....or a USA type bulb numbered "1034"(this is for stop/tail/parking/and directional) Good luck.(P.S. the "flashing indicator unit" is a LUCAS FL.5, if it turns out your flasher is on the fritz...)
RVMAN
Go with what Dave said and use XX57 type bulbs. The info I gave you was from the older maintenance manuals.
Y
ynotme2
Dave to the rescue again. Sorry I didn't mention it but I have a 65 BJ8. In need of some restoration..... LOL.... But love to drive it and learning the in and outs of the car. Thanks for you help everyone
Y
ynotme2
Has anyone used those LED ones instead of the standard bulb. I saw them at Autozone and was wondering if they are brighter or longer lasting or what the deal was.
Thanks
Tony
Y
ynotme2
Well now the real fun begins. I went to the front park turn lamp on the right side of the car. I unscrewed the lens cap, made note of bottom screw missing, and removed the lens cap. Everything was looking good. The gasket was harder then petrified wood. I removed it and notice the bulb was recessed intot the socket. I tried like the damnest to twist the lamp. I shot some wd-40 in there and then the bulb started to come out. As I wiggled the bulb left to right and up and down. The bulb cam out but it looks like if contact had corroded onto the back of the bulb. After wiggling them some more the bulb cam loose and away. But it looks like 2 exposed wires. So I figured that I will order a new bulb base for the front. But now I am confused. I have a 1965 BJ8. I am looking at the Vicki British Catelogue on page 88 on the fall edition. I am not sure which to order? A bayonet base, item 14-971 or a screw base, item 14-972, or a screw base "claw type", item 14-973? I think I want the screw base type but unsure? Any ideas? Also how do I attach? Do I solder it to the base? Or as I see in the Moss Motors catelogue there is a bulb contact kit. I would assume that would be the better way to go?
Thanks
Tony
Bugeye58
Tony, you can get the contact repair kit at your local NAPA or Auto Zone for less than 3 bucks. If you do order a new base, you want the bayonet style. Solder and shrink wrap the wires together.
Jeff
Bugeye58
Tony, I've used several of the contact kits from NAPA. They come with the fiber washer, the two contacts and wire pigtails, as well as the spring. And, you don't have to wait for the big brown truck to show up before you are on the road again!
Jeff
Y
ynotme2
Well i got the new pig tales as they called them. I will solder them on but...is there a direction the 2 brass nipples have to be in. Are the supposed to by in the 9 and 3 postion or the 12 and 6 position? Or does it not matter?
Thanks
Tony
Bugeye58
Tony, isn't there a little slot in the fiber washer that lines up with a bump in the socket? I can't remember which way they are oriented, but I'm pretty sure there is an orientation slot in the thing.
Yes, it does make a difference, as they have to be in the correct placement when the bulb is rotated into position, or it won't make proper contact.
Jeff
Dave Russell
Yoda - R.I.P
[ QUOTE ]
I shot some wd-40 in there and then the bulb started to come out. As I wiggled the bulb left to right and up and down. The bulb cam out but it looks like if contact had corroded onto the back of the bulb. After wiggling them some more the bulb cam loose and away. But it looks like 2 exposed wires. So I figured that I will order a new bulb base for the front. unsure? Any ideas? Also how do I attach? Do I solder it to the base? Or as I see in the Moss Motors catelogue there is a bulb contact kit. I would assume that would be the better way to go?
Thanks
Tony
[/ QUOTE ]
Hi Tony,
If I read you correctly, it sounds like the brass bulb base has separated from the glass bulb & is still stuck in the socket. I'm not exactly clear on which part separated. The glass, the brass base with it's contacts & bayonet pins are all part of the bulb itself. If only the glass bulb with it's two bare wires has come out, the brass base is still stuck in the socket. You can sometimes work the base out of the socket by jamming a piece of rubber hose into the lamp base & using it as a handle to work the base out of the socket. If things are really stuck you will need to replace the socket assembly. The contact kit alone will not help.
From your description, (lens cap screws) it sounds like you have a later model BJ8 which uses a different "bulb holder & lamp body" than the earlier cars. Probably with separate turn signal lamps.The change was made at car number C26705 & up. If so, the previous advice about bulb numbers etc. is not correct & you will need a single element bulb. Check out this Moss catalog page & see if you can figure out what you need.
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=28938
If necessary, you can get the whole new lamp assembly.
If the lamp base is NOT stuck in the socket, follow Jeff's advice.
Y
ynotme2
Thanks guys. I will look at it closely. I have a single lens 65 car. Not the double lens front of the last seriers. The bulb and base came out all together but not that I tihnk about it, there was no spring. It was tough to get it out and the bulb seemed to have welded itself to the contact opints. I will have to look for the slot to see how to orientate it. Can I ask how the base plate attaches to the car itself? I assume that there are 2 nuts from behind the body, in the wheel well, that hold the base plate in against the body? If the bulbs were not the cause does the flasher units go out much in the cars?
Thanks
Tony
Keoke
Tony, the base plate is attached by two studs with nuts on the rear. Your problem sounds like water has gotten in side the lamp and either frozen the spring or rust has caused it to fail. The socket will require a very good clean up. and the new parts should slide freely in the lamp socket bore after being installed. To my Knowledge flasher failures are not a problem. In addition to the spring and contact assy you will require a new lens seating washer I suggest you use two of them-FWIW---Keoke
Keoke
Tony, Here are the parts required to repair the lamp assy as a worst case; Lens Clear $10.75 Bulb Twin filament $1.oo Gask Lens seating $1.95 Pad Lamp-to-Body $2.00 Bulb Contact Kit $8.85 total cost Less than $25.00-FWIW---Keoke
Y
ynotme2
And so the saga continues. I bought the part and took the base plate off to make sure that the hole was clear and the base of the bulb was still not in the base plate. I take the base plate off and the whole back side is corroded off. Gone. So I go down to the NAPA auto store and they say they have a bucket that would go on the back of the base plate. It goes through the plate and then it looks like there are flanges that get bent down to hold it in the base plate. Around 5.00 and change. Does this sound right? It has two wire connectors off the back of it. Any ideas folks? Thanks
Bugeye58
Those "flanges" are actually spring fingers that hold the socket in place. If the hole in the lamp is the right size for the replacement socket, it should work. You may want to run a bead of silicone around the back side to seal it after you get it in.
Jeff
bighealeysource Right side blinker light flashing faster than left Austin Healey 6
AUSMHLY intermittent right blinker Austin Healey 14
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
G Right-Side Shock Weeping Oil Austin Healey 1
C MGB Which Weber DGV is the right one. MG 14
P Jag XJ8 starts but then dies right away. Jaguar 4
Popeye General Tech O/D right angle drive choices Triumph 10
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
BritBite Speedometer Right Angle Drive Austin Healey 5
drooartz General MG Surprisingly enough, I was right! MG 7
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
C TR2/3/3A Right oil Triumph 8
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
red57 Steering not right Austin Healey 66
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
dougie Big Healey Six - Used the Right Way Austin Healey 5
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
C Left to right hand drive Austin Healey 2
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
T TR6 grinding right rear wheel Triumph 22
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
Rut TR4/4A Nice project for the right person Triumph 0
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
D BJ8 pulls right on hard braking? Austin Healey 4
Simmo TR6 Right Hand Drive Conversion Help Triumph 3
Jim_Gruber 13" Tires - What's out there right now Spridgets 21
Popeye TR4/4A Seats - left/right Triumph 8
TomMull Post-War Other Herald 13/60: I didn't get the battery tray quite right Triumph 4
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
Simmo TR6 Right Hand Drive conversion Triumph 5
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
Zimmycobra TR4/4A Who's right - float height on ZS 175CD? Triumph 5
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
spartan0199 BT7 Right Front Brake Drag Austin Healey 30
S TR2/3/3A right to the wheel well Triumph 10
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
Got_All_4 TR2/3/3A 2 questions; raising the body and taking out that lean to the right Triumph 12
Jim_Gruber NOS 10 Post BE Windscreen on E-Bay right now - NFI Spridgets 3
S TR4/4A water pump doesn't feel right Triumph 2
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
P T-Series TD Door Hinges: just what is the difference between right and left? MG 11
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
trrdster2000 GT6 Where to find the right tire? Triumph 8
