Retractable Seat Belt-Mine has been eaten
Jim_Gruber
Was having issues with shoulder belt locking up and not coming out due to angle it was mounted at. Bracket behind seat had twisted so that it wasn't quite level and I had to put Bugsy in a nose up attitude on an incline in order to get the seat belt lock to release so I could pull out.
So to make a long story short, I unbolted the retractor to tighten the right angle mounting bracket and the retractor has eaten the majority of my belt and doesn't want to give it back. Varying angles doesn't seem to help. Any solutions.
There is some sort of adjustment wheel with a big arrow on it says align arrow with arrow on side of retractor. What is the purpose of this adjustment wheel? And other than tossing the whole thing out and getting another set of belts got a solution.Since 99% of the time I am the only driver of Bugsy, I just may try to swap passenger belt and see if I can make work at least for this weekend.
The arrows on mine are supposed to be pointed up.
Jim_Gruber
Jim_Gruber
Well got it to release on the bench but now struggling to get reinstalled and working. More fiddling in order. Swapped out those flat 11/16 sized bolts for something in same thread and taller so socket can get a grip on it.
Jim_Gruber
Jim_Gruber
OK trick is to align big arrow on side of retractor so it is straight up and down, Adjustment knob must point and align with big arrow and tightened down so it does not easily rotate. Now to reinstall the back of the top. A typical LBC "fiddley bit" thing to adjust.
T How did you mount your retractable seat belt? MG 6
I TR6 TR6 retractable seat belt source? Triumph 10
S Retractable Seat Belts Spridgets 3
Got_All_4 TR2/3/3A Suggestions for shoulder harness retractable/inertia seat belts Triumph 4
Lotuswins BJ8 3 pt retractable Seat Belts Austin Healey 10
7 Retractable seat belts - BT7 Austin Healey 8
Michael Oritt Retractable two-point seatbelts Austin Healey 12
brgrmyster Kangol Reflex retractable seatbelts Jaguar 4
G Fully retractable radio antenna Triumph 5
A Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
J Wanted TR6 seat vinyl Triumph Classifieds 1
Editor_Reid Leather Seat Repair Austin Healey 5
Healey Nut Seat Base Frame Position Austin Healey 4
J TR2/3/3A TR3 Rear seat Triumph 11
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
D TR2/3/3A seat runner placement Triumph 1
H GT6 ...and a basketweave seat cover question Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
J TR4/4A Seat identification Triumph 3
J Wanted- Late TR4 seats or seat frames Triumph Classifieds 0
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
T Bugeye seat recline Spridgets 5
RJS General TR TR4A Seat Rebuild Triumph 12
M BJ8 Seat Thickness Austin Healey 6
F Seat Covers Austin Healey 1
P For Sale mgb seat covers MG Classifieds 0
nichola TR6 Seat belt reinforcing plate question Triumph 15
W TR6 Seat diaphragm failure on 2nd seat! Triumph 8
C Seat Cover Bugeye Sprite Mark 1 Spridgets 5
R TR2/3/3A Seat Installation Triumph 13
R TR4/4A Early TR4 seat pans Triumph 26
R 3-point seat belts on late production BT7 MKII Austin Healey 7
Michael Oritt Seat belt anchors--introduction Austin Healey 2
RAC68 Front Seat-back Angle Austin Healey 14
SherpaPilot TR6 Difficulty with New Seat Diaphragm Install Triumph 6
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
A TR2/3/3A Rear seat Triumph 9
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
L Seat position for a BN1 Austin Healey 0
M Wanted TR6 Seat Rail Triumph Classifieds 4
Upland Sprite seat back rake Spridgets 0
C Healey seat recline Austin Healey 7
J TR6 seat track location on new pans without holes for seats Triumph 2
S BJ8 Rear Seat Side Panels Austin Healey 3
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
S Wanted MGB Static Seat/Shoulder Belts MG Classifieds 0
P Seat Bottoms And Bases Don't Seem To fit Together Well Austin Healey 4
J TR6 75 TR 6 seat track location Triumph 11
6 Seat Covers Spridgets 9
R Seat frame alignment with seat back Austin Healey 18
