Hey all,
Went to remove my cracked glass windscreen on my 100-4 this morning. Of course, easy to remove the entire assembly and you're left with the aluminum posts that are attached to the actual chrome frame that the glass fits in. DUMB question and cannot see what I am missing, but how do you get the chrome sides un-attached from the aluminum posts ? Took the two small screws at each top corner off and the chrome piece is loose at the bottom but seems to be well secured towards the top. Checked out the holes where the small post screws in where you attach the windshield security spring assembly but as far as I can tell, no set screw or anything at the bottom of that hole on the post. Anyone replace your glass recently ? Sure it will end up to be a simple solution but I'm sure missing it !
Thanks,
Mike
Thanks,
Mike
