removing exhaust/intake manifold
bcbug
I know this has probably been asked before but how do you get to the two bolts in between the exhaust and intake manifold on a 1500 motor. I have tried everything I can think of. I can get a wrench on the rear bolt but I cannot get anything on the front bolt. There has to be a way to get to it but I can't figure it out. Help!!
G
PO made a tool out of a box end wrench cut out on one side and bent around a bit.
I took mine off yesterday and the tool didn't work so I took the WIDEST 9/16 combination wrench and put the open end straight on the nut (like it's eating it from the front) Then I put a screwdriver in the box end and used that to turn the wrench. Use a wrench that has a wide box end. I have a DGV and it's a pain to get to but that'll work.
Alvin
Member
Get a S box wrench. It is shaped like a S and it works. I just put my manifolds on and I was able to do it with this special wrench. No way to torque the nuts properly, but getting them "real tight" will work.
Alvin
Member
Another reported method was to get a "coupling nut" and use it rather than the standard exhaust/intake nut. The extra length of the nut would give you more room to get a wrench on it. I decided to go the S wrench way because a coupling nut of the correct size would cost almost the same as an S wrench set on EBay and the wrench set could be used again.............although this is the first time in 40 years that I have had to use a S wrench. However, I just started working on British cars!!
RichBall
Alvin
My 1500 had a major vacuum because the DPO decided to leave that manifold nut off. The stock nuts on the two lower center studs should be long like a coupling nut.
For 1500 engine parts like this I have found that Sprtbits in California has the best price and carries stuff that Moss and VB don't. NFI
https://www.spitbits.com/
G
I'm thinking about changing it out to an allen and using a ball end wrench.
wkilleffer MGB Removing the exhaust manifold on an MGB MG 15
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
