MGB-GT Removing a GT Fender.
vping
Bronze
I got a few rusty fenders I need to remove but figure I'd try and do it the sane way first before I whip out the Sawzall. Any tips on fender removal?
tony barnhill
Great Pumpkin - R.I.P
Front fender? Bolts along the top edge, 4 in the front grille opening, bolts along valance seam, 2 or 3 up under bottom edge by rocker, & the ones behind the kick panel & dash inside the car....just time is all it is.
Platinum
A 1/2" windy (air wrench) will make this a quick job, too. Bolts either come OUT or snap off.
20 minutes, tops. Problem solved! /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
tony barnhill
& I think 7/16" for the bolts along the valance...don't even try to loosen the ones up under the bottom edge by the rocker...just whack them off!
Platinum
I could say soooo much.... but instead I'll say: "yeah, whut HE said!"
/bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Gillard1979 MGB
Removed all the bolts along the top of the fenders, the three along the bottom and under the front grill, three inside above the door frame, the three on the splash pad but fender is still not off the vehicle... just wondering if there might be behind the kick panel /pocket...
LarryK
As Tony said, behind the kick panel and dash.
TR4 TR4/4A Removing a rear fender on a TR4 Triumph 7
G Advice needed in removing front left fender. Triumph 2
66healey removing rear fender Austin Healey 3
N Removing Front fender MG 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
