TR6 remove transmission
zeke5
I am about to remove tranny from my 75TR6 (broken taper pin).I have disconnected the driveshaft flange from rear of tranny.The driveshaft flange went back and down approx.1.5 inches.Do I have enough room to remove the tranny or do I have to remove the driveshaft first?Thanks.
poolboy
You should have enough room..I've helped on a couple of those jobs and we never removed the drive shaft...
You are removing the tranny thru the cockpit, right ?
And upon reinstalation, if there is one single most important thing, I'd have to say make sure you have those 2 dowel pins (moss #325-205) for alignment. They would be in the rear engine plate
poolboy
Yes, isn't that what you were asking about ?.. .And especially when reinstalling, put a jack under the engine so it won't be drooping down.. you want it level to facilitate alignment with the tranny.
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
R Remove engine/transmission advice needed Austin Healey 4
C TR4/4A Best way to remove transmission fill port? Triumph 8
L Transmission seals- how to remove? Spridgets 7
M Outline to remove motor /transmission Spridgets 11
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
CARSINC How to remove factory contact cement? Spridgets 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
drooartz Hose from water pump to head, remove water pump? Spridgets 12
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
tahoe healey Nano Magic scratch remove Austin Healey 2
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Basil 7 Ways to remove stripped screws Restoration & Tools 2
C How to remove entire dash panel on BN6? Austin Healey 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
C MGB How do you remove "speed nuts"? MG 9
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
abarth69 Should I remove this section Spridgets 8
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
D TR2/3/3A wooodruff keys... how to remove Triumph 25
B remove BJ8 dash ? Austin Healey 1
Steve1970 TR6 Can I remove the shim on the rear gearbox mount [J-type OD] Triumph 11
4tecdog Access to remove Ariel Austin Healey 15
L Best Polish to remove surface scratches Austin Healey 12
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
P How to remove the lever control? Austin Healey 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
D BJ 8 How to remove chrome trim strip from door tops Austin Healey 7
S TR2/3/3A remove protective covering off floor pans Triumph 6
bighealeysource Best way to remove dried polishing compound Austin Healey 10
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
NutmegCT How to remove old weather stripping Restoration & Tools 8
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
B Remove Crank Nut Austin Healey 55
R Can't remove rear flexible brake hose Spridgets 5
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
S TR2/3/3A remove a clutch fork Triumph 1
maxwedge5281 remove 100-6 grill emblem Austin Healey 1
J TR2/3/3A Remove old dash vinyl. Triumph 2
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
Boggsy64 MGB Advice - Remove the seats MG 8
C How to remove temp sensor at block? Austin Healey 16
