TR2/3/3A remove a tr3 gas tank
tomgt6
is it hard to remove the gas tank from a tr3
what are the tricks to getting it out.
TR3driver
Great Pumpkin - R.I.P
Probably depends on which TR3; there were at least two and maybe 3 slightly different arrangments. I haven't done one in a long time, but I remember it being a PITA both coming out and going back in.
The later style fill cap will no doubt make it easier; with the early cap I wound up cutting through the section of hose that joins the inside half of the cap to the tank. Then to reinstall the tank, I cut the new hose short enough that it would fit entirely onto the tank neck while I slid the inner piece of the cap into place. Then comes the fun part of screwing the cap halves together, without cross threading and winding up with the cap in the right orientation. Once that is done, fight the section of hose into place so it bridges the gap, and tighten the clamps. (You did remember the clamps, right?)
Don't forget to remove the outlet line and the vent line before you start with the tank.
TexasKnucklehead
The cap and hose aside, it's easier to get out from the 'occasional' rear seat side, rather than through the trunk. -It may not even be possible to get it out through the trunk. The two holding straps are bolted through the floor to the underside, so I would start by cleaning the exposed threads on the underside. A little penetrating oil there early might help considerably. I think if you prepare for the worst, it will be easy. If you think it's going to be easy... prepare for the worst.
In either case, good luck, it's not that hard of a job.
Kleykamp
PITA is correct, especially on the earlier design. The bolts holding the straps are in the rustiest area of the car on trunk side. Only will come out through the interior side. I have done two earlier (pre 60K) models. I now have the later post 60K model and it doesn't appear to be quite as much of an issue with clearance at the top. Biggest problem will be the strap bolt. not a question of if they are rusted, question is how much.
PKPoole
Hello Tom,
I've done this a number of times in the last year trying to run down what I thought was a tank leak (I was wrong). My car is a post 60000 VIN so it has the newer style cap, but I don't have to take the cap off the body. I pull the tank out into the trunk-side. You have to remove the seat back to undo the tank straps in the front, then the rear, then I just loosen the hose clamp on the TANK (ie the lower hose. my hose is relatively new so a bit more flexible than ones that have been on for years). Then I grab the bottom of the tank and pull the lower section of the tank off the piers until the fill hose drops off the top. Out it comes. Good luck. Pat
T
tomgt6
Thanks for the help. I have the pre 60000 body so I guess I am in for some fun. The owner told me the last guy couldn't get it out so I knew this was going to be hard.
T
tomgt6
I have another question. The filler hole in the metal doesn't line up with the tank. The tank is about 1-2 inches off from the hole in the metal. It doesn't seem like there is much room for alignment.
TR3driver
Could it be the wrong tank? There were several different ones of those, too. Mine have all been within 1/2 inch or so, once the tank was repositioned to match.
Hidden accident damage is a possibility too.
T TR2/3/3A How do I remove fan on TR3 heater motor? Triumph 6
M TR2/3/3A Remove and replace distributor in TR3 Triumph 39
B TR2/3/3A TR3 Windshield-[screen]? Holder on'r thingy remove Triumph 6
Got_All_4 TR2/3/3A To remove the TR3 apron or not to remove the apron Triumph 4
PeterK TR2/3/3A How do I remove TR3 door capping Triumph 6
Earl TR2/3/3A Remove Rear End from TR3 Triumph 5
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 2
drooartz Hose from water pump to head, remove water pump? Spridgets 12
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
tahoe healey Nano Magic scratch remove Austin Healey 2
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Basil 7 Ways to remove stripped screws Restoration & Tools 2
C How to remove entire dash panel on BN6? Austin Healey 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
C MGB How do you remove "speed nuts"? MG 9
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 16
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
R Remove engine/transmission advice needed Austin Healey 4
abarth69 Should I remove this section Spridgets 8
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
D TR2/3/3A wooodruff keys... how to remove Triumph 25
B remove BJ8 dash ? Austin Healey 1
Steve1970 TR6 Can I remove the shim on the rear gearbox mount [J-type OD] Triumph 11
4tecdog Access to remove Ariel Austin Healey 15
L Best Polish to remove surface scratches Austin Healey 12
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
C TR4/4A Best way to remove transmission fill port? Triumph 8
P How to remove the lever control? Austin Healey 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
D BJ 8 How to remove chrome trim strip from door tops Austin Healey 7
S TR2/3/3A remove protective covering off floor pans Triumph 6
bighealeysource Best way to remove dried polishing compound Austin Healey 10
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
NutmegCT How to remove old weather stripping Restoration & Tools 8
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
B Remove Crank Nut Austin Healey 55
R Can't remove rear flexible brake hose Spridgets 5
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
S TR2/3/3A remove a clutch fork Triumph 1
maxwedge5281 remove 100-6 grill emblem Austin Healey 1
J TR2/3/3A Remove old dash vinyl. Triumph 2
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
Boggsy64 MGB Advice - Remove the seats MG 8
C How to remove temp sensor at block? Austin Healey 16
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
Lukens TR2/3/3A Before I remove my steering box... Triumph 10
toysrrus TR2/3/3A What tool to remove Dust Cap? Triumph 12
