Reinstalling front springs.
healeyboz
Definitely jack it into place. You might need an extra hand to help push down the car depending on how stiff your springs are. Are they original?
jlaird
Jack up the A arm with em in place.
Billm
That may be the best way but I have always had trouble getting all of the bushings to go in easily so I first put the a-arm in place and then use some 6" long pieces of 5/16 allthread and bring the spring pan up to it.
-Not a better way, just different-
Bill
spritenut
Jack the car up real high, remove the top trunion bolt on the king pin and lower the A arm to point to the ground.
Stick the spring in, you may have to give it a nudge by hand or even a kick with your foot. Be carefull not to kick the car off the jack stands.
Jack tha A arm back up and put the trunion nut back on.
With the arm lowered, there is no pressure on the spring, this works just fine when you remove the springs too.
Spring pans never come off the A arms and it's a 5 minute job.
healeyboz
Agreed.
A 5 minute job if you can get the trunion bolt lined up. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
B
BWillis
I removed them my lowering with a jack but on the first look before reassembly the A arm it pointing nearly straight at the ground. It just looks like it will be tough to get a jack under there and have it push straight up on the arm.
I'll give it a shot.
jlaird
There ya go, wasn't that easy? Special tools, gesh.
regularman
Just be careful with springs, learnt my leeson on them at 18 working at a garage when we were attempting to put a new spring in an old cadillac converitable (the kind with the 500 cubic inch engine). We were using the boom and winch off the wrecker to pull the a arm up and the the spring came out. Went straight up in the air (almost out of sight) at the service station in the middle of town with heavy traffic. Luckily it came back down in the parking lot (took out a chunk of pavement). We used some exhaust u clamps to keep that from happening again. Was like a bomb went off. Lesson learnt /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
jlaird
Oh yea, but the BE spring setup with a floor jack is the only way to go. When they get up just a bit they are locked in unless you do something real dumb.
KVH General Tech Reinstalling TR4A Interior Triumph 13
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
T TR4/4A How do you go about reinstalling cylinder head? Triumph 7
B Reinstalling 948 engine Spridgets 7
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
Jim_Gruber Reinstalling Rear End in a BE - Quick Steps Spridgets 8
Lin Reinstalling rear springs and axle in 64 MK2 Jaguar 1
T MGA Grease axle stub before reinstalling hub on a MGA MG 2
T TR4/4A Prep before reinstalling TR4a gas tank Triumph 2
TRnorwegian Reinstalling the old Strombergs Triumph 2
TR4nut TR2/3/3A Question on reinstalling pinion flange on TR3A Triumph 8
T Reinstalling radius arms etc... Spridgets 4
zimmy reinstalling windshield Spridgets 1
G Reinstalling my Roller Rockers Triumph 4
J help with reinstalling the rear diffy on a 6 Triumph 8
MGTF1250Dave Reinstalling Cylinder Head MG 3
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
