Recommendation on new harness for Bugeye?
tdskip
Any recommendation on where to source a new harness for my Bugeye? Unfortunately would be turning any wrenches on it immediately but want to start gathering all the bits to do it right.
Thanks!
Britishwiring.com used to have excellent service and were very knowledgeable. It has switched owners since the last time I dealt with them, so I can not say if the new owner is as knowledgeable or helpful. However, it is worth giving him a call.
jlaird
Moss worked great and Miss Agatha was happy.
tony barnhill
Great Pumpkin - R.I.P
BritishWiring, Moss, VB - everybody uses the same factory in the UK so all the wiring harnesses from the usual suppliers are all the same...so, what you're really looking for is the best price.
... and best service. There are variations in some harnesses.
tony barnhill
Trevor...when I was doing the wiring on my '63 Midget, I bought a Moss harness - the correct replacement for mine....it came packaged in a bag inside a bag...the inside bag was from the factory in the UK, the outside bag was Moss'....I had a question about a white wire so I contacted Moss & had them research my question....while they were doing their research, I called British Wiring & had them pull a harness off the shelf & read me the factory part number on it - same as Moss!
At the same time, I ordered a harness from VB, knowing I would probably return it but just in case I needed it...when it arrived (before I sent it back), I opened the package - a VB tag & Moss tag on the outside bag with factory bag inside! VB got their harness from Moss!
I talked with the factory about my question & they confirmed the number on the bag was, in fact, their number for a '63 Midget harness.
So, I'm wondering how there could be variations in harnesses that all come from the same factory?
Oh, the answer to my question was that the factory does not build a separate harness for Midgets with pull handle starters; so, the extra white wire for later starters has to be cut off where it exits the harness.
bill_young
Tony, what color was the wrapping on your harness for the 63? I've been told that US spec harnesses had blue wrapping and UK harnesses had black wrapping, at least on the later cars. Not a real issue with my car, but just curious as to which color a bugeye would use or is that one cloth wrapped?
Tony, I mean ... just what you said. There are variations in original harnesses made for the cars. I do not doubt they all come from the same place. However, if the vendor is knowledgeable they can help you understand the variations and how to accommodate for your particular car.
tony barnhill
Bill - mine is just like the original cloth....in later years MG went to blue plastic on some cars....& if you want a cheaper harness than the woven cloth, you can order an early harness in the blue plastic.
Well, we know 1 who can't & the only one who even offered to find out was Moss - they emailed the factory in the UK....since I had had a custom harness made by them a few years ago (under the old owners of British Wiring), I had the factory's phone number so I just called to get my answer.
Now, I'm not knocking any particular vendor...I'm just saying that they're all the same & the person ordering the harness needs to know what they want/need. That's all.
T TR4/4A Recommendation on top for a late TR4A Triumph 8
B Recommendation on wheels Austin Healey 19
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
G Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
Jim McCauley TR6 TR6 Radio recommendation Triumph 4
S TR2/3/3A Front coil spring recommendation? Triumph 7
JimTR4 TR4/4A Battery recommendation Triumph 11
S Grease Gun Recommendation? Spridgets 7
M General MG Shop recommendation....Baltimore - Washington corridor MG 9
M TR2/3/3A Shop recommendation---Baltimore-Washington corridor??? Triumph 4
maxwedge5281 auto transport recommendation Austin Healey 10
G General TR Machine shop recommendation around Green Bay, WI Triumph 1
Marvin Gruber BJ8 convertible top recommendation? Austin Healey 0
R Seeking Upholster Recommendation Austin Healey 4
D Recommendation for new core in original 1967 Austin Healey radiator Austin Healey 5
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
C Recommendation for Healey mechanic in Naples/Ft. Myers Florida area? Austin Healey 11
S Rust treatment recommendation? Austin Healey 5
P Good fitting car cover recommendation? Austin Healey 9
DornTRoriginal TR2/3/3A TR3 Battery Recommendation Triumph 9
S Recommendation on Head Gasket? Austin Healey 14
I Bigeye fuel filter and placement recommendation? Spridgets 8
T TR2/3/3A Camshaft Recommendation Triumph 13
tmcarthur Tool Recommendation Spridgets 7
PAUL161 T-Series New Firestone Tires Recommendation MG 2
B Recommendation for Healey Blue and Old English White Paint Austin Healey 15
bighealeysource recommendation on replacing rear brake cylinders Austin Healey 13
B Replacement Interior Recommendation Austin Healey 11
J Lotus europa 5 speed need recommendation for transmition work [Flordia] Lotus 3
J Restorer recommendation Austin Healey 33
L TR4/4A Surrey Top repair recommendation Triumph 2
P Overheating after shut down & recommendation on thermostat Austin Healey 3
M Pebble Beach/ Monterey Good Accommodations Recommendation Austin Healey 13
S Texas restoration recommendation? Austin Healey 2
B Interior Recommendation Austin Healey 8
H Carb rebuilder recommendation? Triumph 5
Patrick67BJ8 Oil Pump Recommendation[s] for BJ8 Austin Healey 12
L PPI recommendation, Jacksonville? Austin Healey 2
B Battery recommendation besides Optima Austin Healey 17
toysrrus TR2/3/3A Spark Plug Recommendation for a TR3: Triumph 9
boeingpilot Shop recommendation Ft. Worth, TX Triumph 11
E TR6 TR-6 Tune Up Shop Recommendation Triumph 7
D Steering Wheel Recommendation MG 4
G SU book recommendation needed Spridgets 7
Michael Oritt Need muffler recommendation Austin Healey 16
This14u Spitfire 1500 Spitfire Header Recommendation Triumph 0
T Thermostat ugliness & temp range recommendation Spridgets 13
T Sway bar recommendation for a Bugeye Spridgets 21
King_of_England Race clutch kit recommendation??? Racing 5
T Recommendation/source for poly bushings Spridgets 2
