TR2/3/3A Rebuild of rear shock for 58Tr3a
PeterK
I took mine off and drained all the old fluid out. Took out the valve and cleaned also.
The old fluid was really dirty and I removed what I could through the drain then flushed with fresh Marvel Mystery oil, working the arms up and down. Then drained the Marvel out, refilled with shock oil from Moss, pumped the arm until they were smooth throughout the range.
As long as yours are not leaking, this may be all they need.
I second the worldwide link if they do end up needing to be rebuilt.
martx-5
:iagree: I've cleaned and put new oil in these lever shocks for many years, even when I worked a a Saab dealer in the early '70s. The Saab 95, which was the wagon designation, had lever shocks in the back. We had a customer come in one time with his 95 and asked if we could put stiffer shocks in the rear because sometimes he carried heavy stuff. We explained that they were lever shocks and it would be possible by putting in heavier weight oil, but not recommended. Besides, heavier springs would probably be better. He was insistent. The service manager said put some gear oil in them and send him on his way. Well, I put in some 75 wt gear oil in them, and they were really stiff. I mean you could hardly move the suckers. I put them in the car, drove it, and came back and told the service guy that it was just too much, the back end was bouncing around over bumps because there was no give in the suspension, except for the tires. He said "Let's see what the owner says". The owner came in, picked up the car, drove it around and came back and said "Perfect!"...nothing like making a customer happy. :wall:
dogdad
As my '6 shocks are needing attention, I've been told that it's possible to do the same thing as Peterk just mentioned (unless maybe major internal work, that is). Strip them down, clean them up inside/outside and add fluid, right?
Not dissing the guy at all (I just now learned about him and his products), but what does he do in a re-build?
tdskip
I don't think anyone is saying don't dive in if you want to do it, but adjusting for time, hassle and knowing is it done right (not to mention not losing driving time since they just bolt up ready to use) Peter and crew is hard to beat.
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
hondo402000 rear shock rebuild Triumph 11
T TR6 TR6 Rear lever shock rebuild: Triumph 3
Carlbanan56 MGB MGB rear break rebuild MG 6
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
A rear brake drum too tight after rebuild Austin Healey 3
M suggestions on vendor Rear brake rebuild Spridgets 15
Gerard TR4/4A TR4A IRS rear suspension rebuild Triumph 10
M Rear brake rebuild process Spridgets 4
Gliderman8 Rear hubs... new or rebuild? Triumph 27
D Rear damper rebuild MG 8
hondo402000 TR6 TR6 rear brake rebuild Triumph 10
N Rear Differential Rebuild Triumph 9
tosoutherncars HELP #2 - rear hub / brake rebuild Spridgets 21
J rear hubs...Something I can rebuild myself? Triumph 24
White79MGB TR2/3/3A TR3 Rear Hub rebuild continued Triumph 2
RedTR3 TR2/3/3A TR3 Rear Hub Rebuild, part 2 Triumph 4
hondo402000 TR6 TR6 rear end rebuild Triumph 7
jerrybny when to rebuild rear hubs Triumph 3
mgbmedic time to rebuild the rear suspension MG 10
71tr Rear Hub Rebuild Triumph 23
skinsgamer Rear Axle rebuild Spridgets 8
77MidgetMkIV rear brake sylinder rebuild Spridgets 3
M Rear hub rebuild? Triumph 13
S Rear springs rebuild MG 5
S rear suspension rebuild MG 4
S Rear suspension rebuild MG 3
6 Master Cylinder Rebuild Spridgets 6
wangdango Carb Rebuild Necessity Austin Healey 3
drooartz MGB Front suspension rebuild is next MG 57
KVH General Tech Rebuild Report Triumph 6
KVH General Tech Initial Start Up After Rebuild Triumph 23
KVH General Tech More Engine Rebuild Questions Triumph 15
G MGB '71 MGB Front End Rebuild MG 2
drooartz MGB A nice milestone since the rebuild MG 3
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
I Bugeye valve rebuild suggestions Spridgets 8
D MGB 25D dizzy rebuild MG 29
R Rib Case rebuild... Spridgets 5
K TR2/3/3A Further to brake caliper rebuild.... Triumph 2
woolfman C39 vs C40 Dynamo rebuild/parts Spridgets 0
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
B TR2/3/3A TR3a steering box rebuild Triumph 19
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
