[ QUOTE ]
[ QUOTE ]
I had a tough time getting a wrench, or a socket, on the bolt head behind the shock.
/quote]
I don't know Dave but I think the bolt head should be on the outside of the shock with a flat washer/split washer and nut on the inward side of the shocks.
/ubbthreads/images/graemlins/savewave.gif
[/ QUOTE ]
I agree Johnny. Bolt heads on the outside or shock side. Nuts in the tight space behind the shock mount. Just reach down & hold the nut with an open end wrench. It will test your dexterity to get the nuts back in place & started. Had to use a thinwall socket on the original rear bolt heads.
I used a combination of 3/8" drive extensions & socket to remove the front shock bolts. Fortunately, there is more room around the bolts on the front shocks so larger diameter hardened washers can be used when you replace the bolts. Don't torque to more that 35 pounds.
BTW, if you jack under the outboard portion of the lower front control arms, you can remove the front shocks quite easily. Remove the upper fulcrum bolt, loosen the bolt holding the two shock arms together. Remove the shock arm to shock pivot clamping bolt at the shock, & slide the arm out a bit on the shaft. This relieves the clamping pressure on the upper fulcrum rubber bushings. Remove the four shock mounting bolts & the shock is loose. A good time to replace the upper rubber fulcrum bushings if needed. Maybe even a good time to replace the shocks with Peter's rebuilts?
