M
Member 10617
This should be quite simple, but it is not obvious (to me). How do you get to the bulb in the flasher lamp to replace it. Do you have to remove the three small nuts accessible from the tunk side?
Also, I have a question about the wiring for these lamps. Each one has a wire going into the rubber boot of the lamp holder. One also has a wire attached to one of the posts and nuts (a ground?). The other has the same kind of wire, but it is not attached to the lamp. Any idea about this?
