Rear End for 1275
Biff
You could use a 3.9 rear end and bring the revs down some or go for a 3.7 and cruise. But the downside with the 3.7 is you will be slower getting up to speed.
Bugeye58
With my 1275, and a 3.9 rear gear, I run about 3600 RPM indicated at 60 MPH. It goes up about 500 RPM for every 10 MPH, so you would be looking at somewhere near 4350 RPM at 75. That's with 15580SR13 Michelins on it. I'm putting 175 70 Sumitomo's on it this weekend, and I'll see what it does then.
With the 3.9, acceleration is acceptable, but I still may drop a 4.55 in, as I never go on the freeway with it anyway.
The 3.7 was in the 1500 cars because they don't rev as high as the 1275 will. And, they are real dogs by comparison. (Don't all you 1500 guys beat me up for saying that! /ubbthreads/images/graemlins/nonono.gif)
Jeff
I think the 3.9 is a good choice (most 1275 spridgets have 3.9's). If you are serious about freeway driving then you should consider making a plung into a 5speed conversion. With 165/70 tires a 3.9 reared and a datsun 5 speed my car turns slightly less than 3000 rpms at 60 mph.
ThomP
Count the number of teeth on the ring and pinion gears; Divide the number of pinion teeth into the number of ring teeth. For instance if the pinion has 9 teeth and the ring has 41 teeth that would be 41/9 or 4.55 for a ratio. "Whiteout" works well to mark the starting tooth.
S Rear End Noises Spridgets 28
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
A TR2/3/3A Rear end locked up Triumph 6
John_Mc TR6 Twitchy rear end Triumph 18
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Rut TR4/4A Rear end questions Triumph 8
H For Sale Rear end bearing and seal set Austin Healey Classifieds 0
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
Rut MGB Rear end service MG 7
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
Rut TR4/4A Which rear end ratio? Triumph 1
Jim_Gruber Bugsy IV - Rear End now Reinstalled - Yeah Spridgets 0
Jim_Gruber Decopnstruction of Rear End over, Reconstruction Begins Spridgets 4
Jim_Gruber Rear End almost out Spridgets 5
Scotsman TR4/4A How to fix sagging rear end. Triumph 8
PatGalvin TR2/3/3A Rear End Problem Triumph 22
SilentUnicorn 3.7 rear end Spridgets 6
Jeepster Wallowing rear end? Austin Healey 27
Got_All_4 TR4/4A TR4 Detroit Locker Positraction Rear End Triumph 6
bugedd Rear end noise [insert joke] Spridgets 11
tr7andtvr Wedge Tr7/8 rear end ID RKC0100 Triumph 4
tinman58 TR5/TR250 Very stiff rear end Triumph 27
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
Boggsy64 MGB Rear end washers easy MG 1
mt10flyer TR2/3/3A Rear End Klunky Triumph 7
R transmission and rear end oil Austin Healey 2
E Rear end is cocked Austin Healey 4
Jim_Gruber Reinstalling Rear End in a BE - Quick Steps Spridgets 8
J Possibly stupid question about drivetrain / rear end Spridgets 11
1 Jensen Healey Rear end / Rear Axle wanted -Texas or surounding preferably Other British Cars 6
bugedd Need some rear end education Spridgets 15
bugedd Limited Slip advice, scrapping idea of RX7 rear end Spridgets 34
Jim_Gruber Pics of how Rear End bolts into a BE Spridgets 21
J Last Step, Rear end: What is this one? Austin Healey 8
5 Uppity Rear End Austin Healey 6
M Replaced rear end, can't reconnect propshaft Spridgets 2
jsfbond My rear end Triumph 2
doughairfield Painting my rear end. Triumph 7
M looking for rear end gears for bj8 Austin Healey 25
6 HELP! something broke in the rear end... Triumph 71
A Rear end weight? Austin Healey 7
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
Jeepster Dodgy rear end Austin Healey 16
jsfbond rear end alignment Triumph 11
G Looking for tranny & rear end help Triumph 3
G TR4/4A tr4 rear end in a tr3a Triumph 10
MgKid1974 Rear End Vibration... MG 3
M RX 7 Rear end option Spridgets 33
J TR 2 rear end axle seals. Triumph 8
