MGB rear disc brakes for an MGB
G
The MGA "Twin Cam" was offered with four wheel disc brakes. Would the rear disc brakes work on an MGB? Could they be adapted in some way to work? Has anyone tried this? Anyone have any suggestions. I was just thinking about improving the brakes on my 1973 MGB and something from MG would be a plus to me.
tony barnhill
Great Pumpkin - R.I.P
don't know about the MGA brakes but I did it on ym V8 car & am doing it on my V6 car...easy to do everything except park brake...that took a bit of work...my web site explains everything along with Advance Auto parts numbers
....let us know about the MGA idea!
trrdster2000
Jim, go with Tony on this. I was going to try this years ago and found out things are not as simple as it looks. There are (if I can remember) 92 different parts compared to the stock MGA just on the rear set up. Wayne
Steve_S
From what I understand, the MGA disc brakes are not nearly as efficient as the B discs. Plus the calipers are nearly impossible to find should you need a replacement. There are adaptor kits to fit B calipers on A front discs but not sure about the rear. Keep us posted on your project!
G
I went to Tony's web page and printed all the information on how he put disc brakes on the rear of his MGB. I will research this further and let everyone know how it goes. thanks for all the input!
D Wedge Rear Disc Brakes for TR7 Triumph 16
Dave Richards Which Cars Had Rear Disc Brakes? Austin Healey 22
T TR6 tr6 rear disc brakes Triumph 30
milemarker60 TR6 My Rear Disc Brakes on the TR6/M3 Triumph 0
Gearhead Rear disc brakes on a Midget Spridgets 2
69MGC Rear Disc Brakes MG 11
A AH 3000 rear disc brake conversion Austin Healey 28
Jim_Gruber Creative Spridgets Rear Disc Kit Spridgets 11
T 'Creative Spridgets' rear disc conversion Spridgets 6
steveg Rear Disc Conversion Austin Healey 28
S Rear Disc Brake Conversion Austin Healey 9
S rear disc brake conversions brackets Triumph 9
M BJ7 Rear Disc Brake Setup Austin Healey 7
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
Fortius Dennis Welch Rear Disc Brake Conversion Kit Austin Healey 2
R rear disc's MG 25
PAUL161 MGB MGB Rear Disc Brake Conversions MG 14
GregW Factory rear disc kits? Austin Healey 28
A Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
Healey Nut Rear Wiring Routing Austin Healey 2
R TR6 Rear suspension droop restraint Triumph 0
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
drooartz Rebuilding rear axle Spridgets 10
S TR2/3/3A rear main seal is leaking Triumph 13
J TR2/3/3A TR3 Rear seat Triumph 11
T crankshaft (rear) bearing leak Spridgets 2
G For Sale: Triumph TR2, TR3, TR3A, TR3B Factory Steel Hardtop, New Rear window, Partial Bracket Set Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
5 TR2/3/3A Seized rear brakes Triumph 9
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
S Rear Wing Fit Austin Healey 4
chicken BJ7 Rear Quarter Panels Austin Healey 3
M For sale rear wings Tr6 Triumph Classifieds 3
Healey Nut BT7 Rear Suspension Austin Healey 15
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
M Have a pair of tr6 rear wings Triumph Classifieds 0
D MGB Rear Suspension Damper Link Arm MG 2
S Rear End Noises Spridgets 11
Jeepster Rear Brakes Adjustment Austin Healey 6
M Wanted TR6 Rear Bumper impact Brackets Triumph Classifieds 0
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
E TR6 74 TR6 - Rear and windshield frame color Triumph 2
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
8 BJ7 Rear rail trim Austin Healey 0
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
