Rear axle- Converting to wire wheels
pan
Can anyone confirm that the rear axle housing used on wire wheel Healeys is narrower than the housing used on steel disc wheel cars?
A member of our local AHOC is restoring an ex-USA 100-6 which was originally fitted with disc wheels. He has fitted wire wheels but now the rear tyres protrude beyond the wheel arch. He does not accept my advice that he needs to swap the axle for a "wire wheel" axle.
My memory may be failing, but I know this is necessary because in the early seventies, a few Healey owners despaired of problems related to aging wire wheels and converted their cars to steel discs.
I recall that the 'wire wheel' axle tube was about 1.5" shorter than the 'disc wheel' axle to allow for the bolt-on hub extensions for the wire spoked wheels, thus bringing the track dimension back to the same as the steel disc wheels.
Looking forward to any comments
I was never aware of a narrower axle housing available, and the service parts list seems to bear that out; no separate listing for disc/wire wheel axle housing or axle-shafts.
MGBs have two (2), or four (4) if you count all years, axles for either disc/wire wheels.
On my own car, I just removed the w/w adapters and bolted on a steel wheel (using the w/w brake drums).
Randy_Gay
The disc wheel brake drums have the dished area filled in. No axle change to my knowledge, just longer studs on the hubs. I think he should look for a set of wire wheel drums.
Keoke
Hi Pan, I think your friend either obtained wheels with no off set or some negative off set. What he will require is a set of wheels with the correct Positive offset.---Keoke
Correct, I didn't make that clear in my post.
Your friend is lucky, the w/w drums are much cheaper than the disc wheel drums! That's why I didn't change them (besides allowing a slightly wider wheel to fit inside the fender).
G
Hi Pan,
Not sure about Big Healeys (and I have a similar question to yours elsewhere on the forum as I also want to swap my BN6 disc wheels to wire wheels), but on my '66 Sprite I had to swap the rear axle housing when I converted from wire wheels to disc wheels, as I was using the car for historic racing- I think from memory the wire wheel axle was narrower than the disc wheel axle, but I could be wrong - so perhaps this is where the axle swap idea comes from.
Cheers
pan
pan
Thanks for the advice. My memory obviously is failing me!
Maybe it was on the 100 only as this model never came with anything but wire spoked wheels. Most of the running gear is shared with the A70/A90 but the drive axles (or half shafts) from these cars are too long for the Healey, but A40 axles can be used.
drooartz Rebuilding rear axle Spridgets 10
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 9
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
warwick-steve Oil for rear axle? Austin Healey 3
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
B How often should you change the rear rear axle oil Austin Healey 9
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
T TR2/3/3A Rear Axle Vent Triumph 12
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
B TR2/3/3A Checking oil in rear axle Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
K TR2/3/3A Rear axle hub removal? Triumph 8
catfood BN1 Rear Axle drain plug. Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
Don_R TR2/3/3A Rear Axle bearings Triumph 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
bugedd Rear axle bump stop Spridgets 7
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
GTP1960 TR2/3/3A replacing rear axle buffer? Triumph 6
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
steveg Learned something about rear axle seal Austin Healey 3
Michael Oritt Rear axle tip needed Spridgets 6
C TR2/3/3A TR2 Rear axle setup Triumph 1
H rear axle bearing numbers Austin Healey 8
K TR4/4A Rear axles on live axle car Triumph 8
J Rear axle noises==BJ8 Austin Healey 7
