Woodie
Good day guys, I am doing some research so I can fix an intermittant problem in the spring. Every so often my tach, wipers,heater fan, turnsignals and fuel guage stop working. The car keeps running. With help from others I believe the problem to be either with the fuse box (green wires/white wire) circuit or the green wire circuit under the dash above my left knee. When I look at the schematic NC9 I can trace the green wires from the fuse box to
1) the reverse light switch (my lights are not hooked up) and then
2)over to a point just right of #37. There is a small circle with 6 green wires in/out of it. These wires seem to go to the affected areas of my car. What is this type of connector. It is not the symbol for a bullet connector. I want to know what I am looking for when I lie upside down and start undoing DPO plastic tape on the loom.
