TR6 radiator air deflector recommendations
ichthos
I have one of the fiberboard air deflectors for my TR6. The problem is with all the moisture in my area, the deflector is all warped and falling apart. Any suggestions on something that looks original, but can withstand the high humidity? If so, can you give me the source? Thanks
Kevin
Geo Hahn
FWIW - I used Thompsons Waterseal on the fibreboard shroud on my TR4, though admittedly I do not live in a wet climate.
I
ichthos
Not a bad idea. If no one else has any other suggestions, I think I will try applying a number of products on my old air deflector, put it outside and see how it stands up.
Thanks
NutmegCT
Seems I recall a fellow BCF member made his new shroud out of sheet metal; that was only within the last year or so. Search the archives and you'll probably find his description.
Tom
tdskip
Paint it with POR15, will last a long time and be water proof. The POR15 will soak into the fiberboard and give it additional strength.
Gliderman8
George beat me to it... Goodparts makes one out of aluminum. I coated my fiber board with clear coat and its held up nicely.
I
ichthos
The sheet metal looks enticing, but I am not sure if I could get it in without scratching it. I never was good at getting that thing in and out of the engine bay very well. If I coated it with POR15, would it be brittle? Can you get POR 15 in anything other than high gloss? Elliot, what do you mean you coated it with clear coat? What brand and product did you use?
Kevin
Gliderman8
I bought an aerosol can of clear coat that you might use over paint.
DNK
Think Kevin is a little wiser ":smile:" with his money
IF not save your own with the above suggestions
VB has a plastic one ,or did.
jdelayknee
I bought a replacement deflector a long time ago and want to install it but have misplaced the mounting screws. Any recommendations on generic (read "cheap") screws that will work and link to mounting diagram.
R Air Intake Deflector - Radiator Austin Healey 8
K Radiator air deflector Austin Healey 6
af3683 TR2/3/3A Radiator Air Deflector / Shroud Triumph 31
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
John Turney Radiator Air Flow Austin Healey 47
Monark192 Radiator lower air duct panel for 74.5 B MG 3
AUSMHLY radiator air shield wire placement Austin Healey 11
S Radiator Air Deflectors Austin Healey 3
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
B Radiator Baffle Installation Austin Healey 4
S Painting a BJ8 Radiator - any advice? Austin Healey 17
S Bugeye Radiator Tank Plug Size? Spridgets 24
FlyingCat Spitfire Electric Radiator Fan Triumph 10
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
FlyingCat Spitfire Radiator and fan Triumph 5
aero3113 Radiator overflow catch tank Austin Healey 15
