Quiet fuel pump for Healey BT7
fishyboy
Hi all,
Despite owning my Healey for nearly 25 years I have recently become fed up with the loud knocking/tapping noise from the pump. I think my car has a SU with electronic points(?). Does any know if there a quieter pump that can be fitted?
Thanks
Phil
RDKeysor
Bronze
Not responding to the fuel pump issue at hand, but the www.asstraldimenson.com site suggested by another member is the best I've seen.
F
fishyboy
Hi all,
Can anyone tell me what sort of noise I should expect from my fuel pump (electronic points SU?, ill check later).
A the moment I get a moderately loud clicking which is allays present, but increase in frequency as the demand changes. under moderate acceleration the clicking becomes ver frequent. Is this correct? Could there be a air leak?
Phil
Hi all,
Phil
Expect a click every 3-6 seconds at idle depending on idle speed, faster as speed increases, fast 'click-click-click' under hard acceleration. If you have an air leak on the intake side, the clicking will be very rapid and/or sporadic at idle. If you have a leak on the output side, you'll smell gas.
vette A Quiet SU Fuel Pump Austin Healey 2
Coyote1 General Tech Is there a quiet electric fuel pump Triumph 11
Jayplum TR2/3/3A Quiet Triumph 12
RAC68 Quiet Leaf Springs Austin Healey 4
N TR6 TR6 Spotted in the New Horror Film "The Quiet Ones" Triumph 3
RickB Since things are so quiet... my new car! Spridgets 21
Michael Oritt Quiet around here Racing 4
zimmy aweful quiet today.... Spridgets 2
Trevor Jessie Might be a little quiet here for a few days Spridgets 24
Brosky Way too quiet in Puerto Rico Triumph 19
Branson Ive been quiet.... Spridgets 62
B A Quiet 1500 Trans !?!?! Spridgets 8
jlaird Very quiet day here. Spridgets 11
delisaj Looking for a quiet muffler Triumph 28
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
