For my TR3A I got a front drivers side fender patch panel from Moss, p/n 855-495. The back end of that patch panel is almost perfectly straight it's entire height of 12 to 13 inches. When I put the door on to check clearances, I noticed that the door has a curve to it. As a result, the door protrudes out past the fender where the door has the curve. I checked the passenger side fender and door and have the same situation, which I had not really noticed before. Although the passenger side fender is far from original and not a good example. My question then is whether the lower back end of the front fender is supposed to be curved like the door, or is it supposed to be straight on the lower 12 to 13 inches? I have attached pictures of both fenders so you can see the gap I'm referring to, although it is much easier to see in person than in a picture. Thanks for the help!
Regards,
Bob
Regards,
Bob
