While I'm at it...famous last words.
If you look at the attached picture you can see where the plug welds are, and while the are all holding it seems to me that there is a lot of metal that isn't welded in place. Would it make sense to run a MIG weld bead down all the joins? It occurred to me today that now is the time to do this if I'm thinking about. It would be pretty easy to run a bead down the metal joints.
Isn't that sort of seam welding done on race cars to help stiffen them up?
