Question on brake line
jackq
While changing out my master cyl. on my 57 A coupe my brake line(approx 55 inches) broke at the fitting into the cylinder. Have searched this town and no results...big shock as if it isn't a truck or a low-rider...they don't have it. Any thoughts as to a source?? Thx.
Platinum
Gah. Hate it when that happens. Is the ferrule ("gland nut") still useable? If 'twer mine, I'd be goin' to NAPA for some Bundy pipe of the same length/O.D. and bend up a new one. Bubble flair the ends using the old fittings.
PAUL161
Doc, Don't mean to hijack this post, just one question. Where can I get a bubble flaring tool and how is it done? PJ
dreamer1uk
Member
You can loan the Metric and SAE flaring tools at must autoparts stores. Autozone loans theres out tor about $15. There very easy to use and im sure you can find a 'How to...' online :smile: Most flaring tools will come with instructions so you can practice on old line if needed.
Id also recomend using the correct flare wrenchs also when working with brake line fittings :smile:
Platinum
I've got my flaring tools from Snap-On and/or NAPA. There's a "kit" of anvils made just for the bubble flare. It can take some practice to get it right, the biggest single "trick" is to deburr the end of the tubing after cutting using a small round "Swiss" file. Get a good smooth edge both O.D. & I.D. and the flare won't split. IOW, remove any sharp edges to reduce the chance of a stress riser. The "kit" has a fair explanation with it (usually) and ISTR there's a really good, thorough explanation how-to if you do a bit of "Gooling". The one I'm recalling may even be on Tony's site. Can't say fer sure, tho.
Grantura_MKI
+1. Look at the Eastwood web site. They offer a flaring set-up similar to mine. Do not purchase a cheap tool, as it will produce out of shape flares. I do agree that most fittings can be re-used in a bind....but inspect they for cracks and miss shape at the end near the flare. Over tightening, etc from years of use produces this. I use new fittings every time.
Cheers,
D.
Platinum
I wuz presupposing a proper visual inspection before re-use. :wink:
jackq
jackq
Shock...walked into the last parts tore in town....Auto Zone..held up my master cylinder and asked if they had a line to fit it...old geezer( like me) says..."MG"?? We walk in the back and there was the tube rack..British flags attached to a few...had what I needed ..I'm still in shock. I'll post the name and part numbers of what they have...sure saved some trouble.
Platinum
:lol: Great score, Jack!
JPSmit
we went through similar at my local Canadian Tire, my young salesman and I measured and approximated the size of a fan belt - took it home and it didn't fit. Took it back, the older lady salesperson says, "MG?" let's look it up - in the computer and in stock! Sheesh, sometimes simpler really is better, who knew?
Grantura_MKI
Lucky man. Out here in Messico, all they stock are chrome wheel covers and boom boom radios and speakers!
Cheers,
D.
Lin Brake hard line question Austin Healey 4
PatGalvin TR2/3/3A Hard Brake Line Flaring Question Triumph 11
tomshobby rear brake line question Spridgets 17
Tinkerman TR2/3/3A TR 3A Brake, Pipe Line Question. Triumph 5
Hooper11772 Brake line question Spridgets 4
E Help...brake line question. Spridgets 16
TR_Jim Spitfire Spitfire Brake Line Question Triumph 2
T TR2/3/3A TR3A Disk Brake Question Triumph 10
T TR2/3/3A Brake system question - Triumph 4
K TR2/3/3A Another brake bleed question....... Triumph 17
K TR2/3/3A An odd brake question? Triumph 2
K TR2/3/3A Brake pad Question Triumph 3
J TR6 TR6 Brake Question Triumph 1
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
K Midget Brake Pedal Question Spridgets 2
bighealeysource Question on 100M front brake cylinder Austin Healey 4
D TR2/3/3A clutch/brake pedal question Triumph 4
K TR2/3/3A 3rd brake light question Triumph 3
D BJ8 brake master cylinder question Austin Healey 6
D brake drum question Austin Healey 5
JPSmit Brake Pads - question Restoration & Tools 10
roscoe Brake pad question Austin Healey 3
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
I TR6 Brake caliper question Triumph 7
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
B Another disc brake question Spridgets 10
PatGalvin TR2/3/3A Drum Brake Question Triumph 3
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
M TR6 Brake master cylinder question. Triumph 2
TomChar TR6 '74 brake failure / oil pressure / ARV wiring question Triumph 19
T TR2/3/3A another brake master cylinder question Triumph 16
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
sd80mac7204 Spitfire 1970 Brake question Triumph 3
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets question about brake master cylinder Austin Healey 12
nevets Question about brake bleeding Austin Healey 13
J MGB Question on the brake warning light for 78 MGB MG 6
C question on the front brake lines for BJ8 Austin Healey 2
D Question on brake rotors Triumph 3
bugedd Brake bleed question Spridgets 9
bugedd RX7 rear axle and brake question Spridgets 2
H brake/rotor question Austin Healey 28
BillD Bug Eye front drum brake question Spridgets 12
nevets front brake hose question-BN6 Austin Healey 18
D TR2/3/3A TR3 brake rotor question Triumph 4
