Question Number III today
jlaird
Just full of it arn't I.
Oil pumps. Yea I know they are cheep, but how do you tell a good one from bad out of the engine.
It looks bright and shiney and a bit of wear on the split for the pin attachment but really looks quite like a new one.
Matthew E. Herd
I believe the haynes manual has a method for measuring acceptable wear limits. However, I've known that the pumps in my engines weren't too new, so I just changed them without measuring them.
ChrisS
Jack,
My Bentley manual says the clearance between the outside diameter of the rotor and the pump body should be less than 0.010”, the distance between the rotor lobes should be less than 0.060”, and the clearance between the rotor and the cover should be less than 0.005”. Matt is right, they’re cheap, just replace it now. It’s a pain to do later.
jlaird
jlaird
Yep, agree on the pain, been there done that not fun at all.
Note to self: Leave new oil pump on list.
B Austin Healey 100/6 vin plate and serial number question Austin Healey 3
A Vin number question Austin Healey 14
J Question on 61 AH Sprite body number tags. Spridgets 8
S General TR Engine Serial Number Question - Observation on a TR4A Triumph 3
J TR6 Commission number question Triumph 2
2billydavies TR2/3/3A question about 1958 TR3a engine number, body number, etc Triumph 7
N Serial number question Austin Healey 11
Stinger TR4/4A TR4A Commission Number Question Triumph 8
B 100-6 serial number Question Austin Healey 4
S Spitfire Question on VIN and engine number for spitfire Triumph 5
C Suspension question number 3 Triumph 3
C Suspension question number 2 Triumph 7
S BN2 Body Number Question Austin Healey 2
jlaird Todays question number II Spridgets 10
Darwin Spitfire Spitfire trans serial number question Triumph 6
S VIN Number question MG 6
tlthorne big Healey engine number question? Austin Healey 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
