# qts of oil, Capacity of radiator healey mk II BJ7
R
Roberte
Member
Sorry Bill, I currently don't have a manual. Trying to decide which one to order. In the mean time I wanted to do some work on the car but need data.
R
Roberte
Member
Actually Iam still deciding which manual to buy. I wanted to do some simple tasks in the mean time. Would appreciate your providing specs
AH100M
My 3000 manual is in my garage but I'm not home right now. I'll check back here first thing tomorrow AM and if you're question's not answered I'll get my manual and look it up.
stevebt7
My BMC Workshop Manual (Copyright 1968) lists oil capacity as 15.3 US Pints and radiator capacity as 21.6 US pints. At 2 pints per quart those would be 7.65 quarts of oil and 10.8 quarts or 2.7 gallons of coolant.
HealeyRick
Steve,
I noticed my workshop manual gives the radiator capacity at 21.6 pints while my BJ7 Drivers Handbook gives it as 22.8 :rolleyes2: At least they agree on oil sump capacity.
stevebt7
My previous reply should have noted that the crankcase capacity in the Workshop Manual includes the capacity of the original oil filter. My experience is that 6 quarts is usually close to capacity if you have a spin-on filter. Also, with a spin-on filter you should fill it as much as possible before installing it and in any event check the level on the dipstick after 5 quarts. I assume that you know that shouldn't overfill the oil. Have fun!
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
O TR6 Oil filter relocate kit Triumph 8
S TR6 Oil Pressure Light Triumph 2
Lin Oil sump sealant question Spridgets 0
H 280i oil filter TVR 2
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
R Oil Filter Removal Austin Healey 1
Lin Oil sump torque value? Spridgets 3
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 5
L BMC A-series: Oil in coolant British Motor Corp 6
A T-Series MGTD oil pump bypass valve MG 0
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
M Oil Pump for BN2 Austin Healey 4
tr6nitjulius Oil flow view inside operating engine Other Cars 4
R TR2/3/3A Oil Leaks Triumph 24
tahoe healey Gold Sparkle in Oil Austin Healey 15
B TR4/4A Oil Drain plug size Triumph 14
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
J TR4/4A Oil Deflector Triumph 4
A T-Series Mgtd oil pump alterations MG 2
S Add ZDDP to gearbox oil? Austin Healey 29
E MGB SU CARB OIL 1965 mgb MG 3
Kurtis No oil pressure Spridgets 5
E Oil leaking from the Tachometer cable Austin Healey 5
Walter74 Oil sump AH spares Austin Healey 5
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Basil Neat trick for reading oil level Restoration & Tools 7
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
nichola TR6 Oil pump drive barely engages Triumph 2
C TR2/3/3A Right oil Triumph 8
Lin Gearbox Oil Austin Healey 4
E TR6 Transmission Oil Seal Triumph 13
A TR2/3/3A A rigged TR3a oil filter housing Triumph 8
B Oil cooler Austin Healey 21
S TR6 After I put in my new oil pump.... Triumph 3
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
Simmo TR2/3/3A Oil filter Triumph 5
S TR2/3/3A Dash Pot Oil Triumph 14
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
2 TR2/3/3A Oil leak in tranny Triumph 4
Nelson Oil leaks again Spridgets 1
D Oil leaks Spridgets 22
V Braking Oil Pressure Austin Healey 16
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
K TR2/3/3A Motor oil for Summertime Triumph 3
Editor_Reid Vintage Oil Austin Healey 12
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
A 76 Midget 1500 Oil filter Spridgets 6
