Project Up-date - Body ID Tags - Success
angelfj1
Project Update - Body ID Tags - Success
I have been working on this project for some time now. I have tried a number of methods, but until recently, the results have been disappointing. I believe that this latest tag is a faithful reproduction of the original. I am using .020 brass stock and an 80 - year old embossing machine that I found at an auction.
Cheers, Frank
Gwilhelm
Re: Project Update - Body ID Tags - Success
DANG close!!! Pretty impressive!! If you didn't have the old tag next to it, I wouldn't of known the difference... I can see some slight font differences but that probably cannot be changed with the embossing machine. Again, when no original is present who would recognize a font difference.... The concurs judges probably wouldn't....
Good JOB!!!
I might need those when I'm near finished with my Tr3.... Will you be selling the tags?
YankeeTR
Nice job of tackling the project head-on!
angelfj1
angelfj1
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Nice job of tackling the project head-on! [/QUOTE]
Yes, and my head has many, many dents from those projects that did not pan out!
But, yes thanks, I am pleased with the results.
angelfj1
angelfj1
Your correct, the font is a little different, but very close. I searched all over, including the USA, Canada, India, China and the U.K. for this "technology". It seems that anyone younger than about 40 didn't understand what I was talking about or ever heard of embossing. The primary users of this method of identification system used to be foundries. They would make an embossed tag (reversed) and embed it into the sand so that the finished casting had an ID number which was "proud" of the surface. Also, some electric utilities still use embossed tags for marking telephone poles. There are new machines available, but the fonts are too modern looking and they are expensive, approx. $3500. I even tried making my own dies from bondo. This is tricky because each character needs a pair of dies, one above and one below the metal "tape". They actually worked but not for long. I was very close to giving up, and then like most things in life, I found this old embossing machine when I wasn't looking for it. I was out with my wife looking at antique furniture. There was an estate auction nearby. The family had owned and operated an old foundry since before WWII. I was looking in the bottom of an old china cabinet and saw the embosser. Had to buy the cabinet to get it. Don't ask me what I paid!!! If you thought that sports cars were expensive, you should see what they want for a broken down piece of original early American furniture. But, that's another story /bcforum/images/%%GRAEMLIN_URL%%/shocked.gif
Brosky
How about a price? Those look really good!
Don Elliott
Frank sent me a new set of number plates for my TR3A in brass. I plan to still use the original EB number plate because it's still so good. But for the past 16 years, I have used a big number plate that a local TR friend gave me from a TR he scrapped. My original one (the lower one) got corroded and eaten away by the battery acid. The one I have been using looked good but it didn't have the correct number. It wasn't the right number as per my Heritage Build Record. Because it looked good, no judges ever deducted points for it in concours events. But now I have the right number stamped out by Frank and I plan to install it when my shell comes back from the re-spray. I had to drill a new hole to the right side of the new brass number plate and trim off about 1/2". Also I had to slot the hole at the left end so it would fit the existing original holes.
Frank seems to have overcome this now.
Thanks Frank
Brosky
I did a similar project when I had my door jambs repainted, but this was pad printed by a friend.
I know that it's not factory stamped, but I'll never be concours, so it doesn't matter to me. I just like the looks of this better.
Yes, I did keep the original plate.
DNK
pad printed??
Tomster
There is one company in the States who embosses brass repair tracking number tags for radiator shops. These tags are soldered directly onto the repaired rads.
BUT your machine has a far more interesting origin!
Brosky
The ink is put on via computer layout and through a pad application process, then baked on for durability.
That's how the entire layout was done on the replacement plates originally and the areas for the VIN, color, trim and build dates are left blank. I just had him do the same with the details.
Brosky
Gracias!
I think....
griff
The tag looks great. Just wondering, have you tried to roll one out after embossing? If you had some way to press them a bit it may widen the font and reduce the ripples at the same time?
Griff
angelfj1
angelfj1
I've had a number of requests for pricing of these tags. I need to work out a few details, but I believe they will be somewhere in the $40 range, free shipping. This will get you a pair of tags in .020 brass. I am thinking I will supply these w/o drilled holes and a bit longer (you can easily trim them) because of the variation between cars. I will also be offering embossed tags, in brass or aluminum, for your TR tool box or anything else you would like to identify. More on this later. Until I have my web page up and running, please contact me by private message or at my email address: trtags@comcast.net
Thank you, Frank
PeterK
Hi Frank,
My 3A only has one brass EB body tag. While I would love a repro EB tag for it, why would anyone want a pair of EB tags? How 'bout an EB tag and that-other-number tag on the firewall?
angelfj1
angelfj1
Sorry. I should have stated that more clearly. The price would include two tags; the EB tag and the Muliners tag. Or if you wish I can supply only the Muliners tag, which is the lower tag closest to the battery and most likely to have been damaged or destroyed by acid fumes.
PeterK
Thanks Frank. That make more sense. Now to figure the appropriate Muliner's number (that-other-number) for my car as both tags are gone from a battery tray replacement long ago.
Peter
angelfj1 Project Up-date - The Grey Lady's body is painted Triumph 17
karl66 TR2/3/3A My 1957 TR3 Project [Album Up-date] Triumph 17
T XKE Project Up-date Jaguar 3
angelfj1 Project Up-date and a Few Questions Triumph 20
B Up-date on my latest project car MG 7
Bret Up-date on Bret's MG Skunk Works EFI project MG 7
angelfj1 Wheel/Tire Project Up-date Triumph 8
milemarker60 TR6 TR6/M3 Project Up-date Triumph 15
Mickey Richaud B Project Up-date MG 4
Mickey Richaud Project Up-date MG 8
George Zeck Project Up-date ..... Spridgets 8
B Car Project Up-date Austin Healey 3
TypeRboy Up-date on the MK1 Cortina project Other British Cars 9
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
C For Sale MG A Project MG Classifieds 2
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
UltimateQuestion For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts Triumph Classifieds 0
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
SteveTheBrewer Spitfire Project Tanker Mid-Summer Update Triumph 0
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
SteveTheBrewer Spitfire Project Tanker Update! Triumph 0
78Z Project Austin A40 Somerset ‘Special’ Other British Cars 10
S 1964 BJ8 Project Valuation Austin Healey 21
T For Sale 1970 TR6 project car Triumph Classifieds 0
Rut TR4/4A Return to 4a project Triumph 6
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
CJD General TR New Project...? Triumph 24
S 1972 MG Midget Mk III Project Car for sale Spridgets 5
HealeyPassion AH Sebring/Ruddspeed EFI project car Austin Healey 6
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
HAN5L778 MGB 1974 1/2 MGB Project car MG 0
Vikingo Tropical A40 Devon Countryman project Other British Cars 42
Healey Nut Tri-Carb Project Austin Healey 213
M TR6 '72 Engine Project, Some Day Triumph 6
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
oldbagpipe For Sale Early 1969 TR6 'Stalled Project' $4500 Triumph Classifieds 0
JPSmit Interesting project - and a twist on the hardtop. Restoration & Tools 12
C TR6 A lot has happened. Update on my project Triumph 7
oldbagpipe For Sale Early 1969 TR6 Project for sale Triumph Classifieds 10
boxofparts TR2/3/3A My long term 30 yr project Triumph 5
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
W Potential New Project Spridgets 3
Bayless New Model A project Other Cars 36
