DougF
Just curious, any good stories of stupid things previous owners have done to their cars.
We've all seen them. Tinster could write a novel. I was looking at a TR3 many years ago. The shop had rebuilt and installed a short block. One weekend, the owner decided to take the car somewhere to have the engine compartment sandblasted. The car sat in the shop parking lot with the mechanic refusing to do any more work on it. Somebody had also welded the front valance to the fenders, making an engine pull VERY difficult.
I once got a TR6 parts car that was bandaged together with aluminum banding. Some one had spent excessive amounts of time carving wood to the shape of the rear fender tips, and quite frankly did a very nice job, but he must have run out of energy, money or time. There was nothing left to the car.
My first TR6 came with a long list of problems. Somebody replaced the rubber donut on the steering column and didn't reconnect the ground wire. Instead, they bolted a strap of aluminum from a peddle cluster mounting bolt and wrapped it around the column. I knew it wasn't right. But it worked...sometimes. Like the day I got it inspected, it worked. Twenty minutes later while waiting at a drive through line, it didn't. A boat was backing up and the prop was coming right for the hood. Not a problem to most, but reverse didn't work because of another stupid fix to the clutch.
It's supposed to rain here today, so I may need some good reading material.
