TR6 Power drain
davjac889
Hello All,
I originally thought my heater was shot. But I left the knob pulled out on low,
well the other day the heater came on. I noticed it because my gauges (temp, volt)
began to drop. I think if I were to let it on, it would burn something up. But I am happy
the heater will work. Also when you pull the heater knob out full, there's nothing.
Any advice?
Thanks,
Bill
dklawson
You are likely to have a couple of unrelated issues. The motor may be gummed up with partially seized bearings and a dirty commutator. It has been years since I opened up any of the Smiths blower motors so I am sorry to say that I cannot advise you on how to work on them specifically. On other Smiths motors I have been able to take the armature out of the casing, clean the commutator, soak the bearings in 30W oil and get them freed up.
The lack of any heat from the yeater could be from any number of possible sources. If your thermostat is stuck open, the engine itself may not be hot enough to give you any heat through the heater core (what does your temperature gauge say the engine is running at?) If it is not the thermostat, it could be a failed heater valve (stuck closed). Finally, if it is not the heater valve it could be the heater core is full of sediment. You can try disconnecting hoses in the engine bay, opening the heater valve and flowing water through the core and valve with a garden hose. Try getting water to flow both directions through the core. Keep flushing (particularly in the reverse direction) until the water is flowing freely and clear with no rust, dirt or sediment).
If you can get water to flow through and you get the blower motor sorted you should have more heat than you want... especially this time of year.
davjac889
Thank you so much. My temp gauge runs right of center. In fact, sometime I'll probably install a fan. I've not thought about the heater valve.
But thanks again.
Bill
mrv8q
On my ' 6, the metal hose 'barbs" on the firewall were nearly rusted closed. Replaced them, hoses, and flushed the heater.
G Electrical power drain pulling down rpms..... Triumph 13
H MGB 1980 mgb no power from ignition switch MG 23
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
M Power Loss Austin Healey 27
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
M TR6 Power Steering Rack & Pinion. Triumph 0
C MGA Where to tap into 12v for a power outlet MG 2
G Power to relays Austin Healey 10
M BN1 Loss of Power Austin Healey 21
S Power Steering Austin Healey 3
M TR6 Adding Some Power Triumph 8
nevets interesting article about converting classic cars to electric power Austin Healey 7
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
S TR2/3/3A power wirer for the heater switch Triumph 16
dougie Paddy Power Austin Healey 3
Drone Dog Lilly under her own power... Austin Healey 7
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
G The Formula Power Fuel Catalyst!???????? Austin Healey 17
tomshobby TR6 power assist for clutch pedal Triumph 12
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
JPSmit DC Power source thoughts Restoration & Tools 11
F 12Volt Bench Power Supply Austin Healey 4
B Power Brake Servo for a 100 Austin Healey 3
R BJ7 wiring power path Austin Healey 21
F BT7 brales poor stopping power - any advice? Austin Healey 19
KVH TR4/4A Engine Power Triumph 10
drambuie Getting more horse power from a Healey 100 Austin Healey 63
AH67 BJ8 losing power and enguine dies Austin Healey 9
L TR6 No power/not enough power to turn signals, wipers Triumph 8
KVH General TR Power Issue on Acceleration Triumph 13
Crankshaft TR2/3/3A Loss of power to wipers ad turn signals? Triumph 11
F TR6 Starter Relay = Low Engine Power Question Triumph 13
PAUL161 6.0 Power Stroke Ford Truck Other Cars 4
J Power windows for BJ8 Austin Healey 22
Editor_Reid "Paddy Power" video - well worth watching! Austin Healey 12
S Installing Power Brakes in BN4, need pics to help locate the Servo Unit installation Austin Healey 10
TomMull Power Hacksaw Restoration & Tools 6
D Power Draw Spridgets 4
T Spitfire Spitfire losing power Triumph 8
M Engine power loss Austin Healey 4
T power under acceleration Austin Healey 15
L TR2/3/3A Tr3a lost power go uphill Triumph 21
S MGB No power MG 9
D TR4/4A Sudden total loss of power Triumph 56
A power bleeder Triumph 18
B Help - broke down on road - battery good but no power to starter Austin Healey 17
Zimmycobra TR4/4A Motive power bleeder - TR4A master cylinder? Triumph 9
